Author Topic: Electric Accessory Connectors??  (Read 6200 times)
Re: Electric Accessory Connectors??
« Reply #20 on: September 26, 2013, 04:56:53 AM »
There might have been a reason for that  ::)
Offline clogan
« Reply #21 on: September 26, 2013, 08:29:05 AM »
Did not want to start a new thread so I did a search here to find those pesky connectors.
I wanted to hook up my Gerbing heated glove liners....................
If I can't do it here, anyone have a simple "non-splice" hook up they've used, other than the battery?
Thanks!
-Mark-
Be sure to use a circuit having its own fuse, whether in-line, or through a fuse block.
2010 Neptune blue C14
2009 blue KLR
2013 DRZ400
Offline RcrBoy
« Reply #22 on: September 26, 2013, 11:20:09 AM »
UPDATE
After some more fact checking. Turns out that the 20amp fused harness for the Gerbing adaptor is rated as such if you're running ALL the heated gear at the same time.  :o
Amperage draw for the Gerbing gear is: Gloves) pair 2.2a, Socks) pair 2.2a, Jacket) each 6.9a, Pants) each 4.0a, Vest) each 4.2a
So for the rider it's 19.5 amps if you're running it all. Thus the 20 amp fuse rating for the harness. Passenger would require a separate 20 fused circuit for thier own gear.
Since I'm only running the heated glove liners once in a while, It's California  ::) , rated at 2.2amp a pair, I'm just going to leave the 5amp fuse alone and wire the harness to the front accessory connector.
Cheers,
Mark  8)
Offline RcrBoy
« Reply #23 on: September 26, 2013, 11:29:07 AM »
http://www.zggtr.org/index.php?topic=10985.0  :thumbs:
Oh my......................
That is a sweet set up!
A bit much for my needs. I did however drool over the Ohlins bits     ;D
