Author Topic: Heated grips/seat circuit suggestions?  (Read 2461 times)
Offline GMan
« on: February 02, 2012, 04:08:20 PM »
I'm installing heated grips and seat on my 09 and want to put them on a switched circuit. I'm hoping some of you with more experience than me (which is pretty much everyone) could recommend one. I've searched for this topic but have come up empty.  Thanks in advance.
Offline So Cal Joe
Re: Heated grips/seat circuit suggestions?
« Reply #1 on: February 02, 2012, 07:34:28 PM »
I haven't done it on this bike but on my Gold Wing I ran a relay from the accessory terminal on the fuse box and connected them up to the relay.
Offline marku8a
« Reply #2 on: February 02, 2012, 08:45:10 PM »
I just installed heated grips. There is switched accessory power available already provided in the stock wire harness. The connectors are the bullet type located in the large black rubber boot located under the left black fairing panel. Very easy to access and put there for just this sort of thing. Sorry that I don't have pictures.
Mark
2009 C14 Red
« Reply #3 on: February 02, 2012, 09:01:46 PM »
Make sure you add a variable controller.  Without it, your butt will be on FIRE (I speak from experience).  HIGHLY recommend the Sargent controller.
« Reply #4 on: February 02, 2012, 09:34:55 PM »
Some good Mexican food Max?
Offline basmntdweller
    • The Profile Brotherhood
« Reply #5 on: February 03, 2012, 09:05:19 AM »
Murphskits makes a switched power bus just for this purpose. It was designed for the C-10 though. I have one waiting to be installed on my '09. Maybe first of next week. I think it was $62. It is going on along with grip heaters, Rostra CC, PCV, full exhaust and a flyectomy.
Matt
'09 C14
'98 DR-350
'03 Honda CBR600RR track bike
« Reply #6 on: February 03, 2012, 09:19:02 AM »
I'd run a dedicated fuse protected relay circuit directly to the battery and then, as others have suggested, use the switched accessory circuit to turn the relay on and off.
Here's some info to help with the front accessory leads, scroll to the bottom for the front leads.
http://www.pbase.com/fredharmon/accleads
Offline GMan
« Reply #7 on: February 04, 2012, 11:52:17 AM »
Thanks, everyone. Very helpful.
Offline con05
« Reply #8 on: February 04, 2012, 12:10:08 PM »
I put both heated grips and a heated seat on my 08.  I used the leads in the front as mentioned and the leads in the tail.  We measured the draw on the system and it handled both on full with no issue.
Silver 2011 C-14
