Author Topic: Is it hot out here or is it just me?  (Read 16610 times)
Offline elvin315
  • Global Moderator
« on: May 18, 2011, 10:52:20 PM »
(Rocky the Flying Squirrel): Hey Bullwinkle, will I have less heat on me if I take the fairing off my Concours?
(Bullwinkle aka Mr. Know-it-all): That's a good question Rocky.
I've ridden my Concours without the lowers on for short periods while performing maintenance and I have to say that I felt cooler both when rolling and at a full stop. Note I said cooler and not cool. That lump between your knees radiates a lot of heat whether clothed or not though when stripped it's not concentrated on your legs. It depends on whether the trade-off is worth it to you. A little cooler on a clear day or a lot wetter on a rainy one. Personally with a pair or riding pants I never feel the engine heat with the full fairing in place. If the heat is what's driving you to can the plastic there are ways to make it more tolerable. They're a little radical but read this through and you'll see the logic.
First install 2fast's Heat Shields. They fill the gap between the gas tank and the lower fairing panels and shield you from hot air. Don't worry about overheating the engine, the cooling system can handle it. Nor worry about trapping that heat. Motorcycle bodywork has enough gaps and openings that the hot air will find its way out once you get moving.
http://pets.webshots.com/photo/2034355400063175854swvchd
http://pets.webshots.com/photo/2634462540063175854NYqUZS
Relocating the coolant overflow bottle and replacing the cover creates a ram air tunnel that adds cooler air to the super heated air off the exhaust pipes.
OEM Bottle Behind Battery
New Bottle in New Location
Ram Air Tunnel
Ram Air Tunnel w/Screen
Use some old black plastic oil bottles to fashion some covers to close the gaps in front of the feet. Since the air flow is blocked it needs another way out.
Left Side
Right Side
Cut a vent or bore some holes in the Belly Pan. Now you've given that hot air another way out. If you prefer not to that's OK too.
Vented Belly Pan 1
Vented Belly Pan 2
There are other tricks like using a cut down windshield and/or installing Airwings to direct cooler air on to your roasting body. You can cover the headers with heat wrap or have them treated with a ceramic coating. Both lower the under-fairing temps by containing the heat inside the pipes where it belongs. A very important tip is to carry water in a drink bladder like the Camelback or Platypus to keep hydrated. I keep mine in my tankbag wrapped with a shop towel to insulate it and keep it cool longer. During the "Dog Days" I wear a mesh jacket with armor, and a wet vest underneath. Like I said before, a pair of leather or Cordura riding pants will shield you from the worst of the heat when stopped. They're definitely warmer than riding with jeans but again, there are trade-offs. Comfort on a hot day or skin grafts on a hospital bed.
(Shorty Shields)
http://www.bakerbuilt.com/bbairwings/concours.html (AirWings)
(Ceramic Coatings)
http://www.heatshieldproducts.com/p_exhaust_wrap.php (Heat Tape)
http://www.webbikeworld.com/r4/camelbak/ (Drink Bladders)
http://www.webbikeworld.com/Motorcycle-clothing/summer.htm (Ventilated Jacket)
http://www.webbikeworld.com/cooling-vests/ (Wet Vest)
Offline PlaynInPeoria
Re: Is it hot out here or is it just me?
« Reply #1 on: July 28, 2011, 02:11:19 PM »
How did you mount the oil bottles?  Are they just cut up quarts of oil?
Offline elvin315
  • Global Moderator
« Reply #2 on: August 01, 2011, 02:16:21 PM »
The pictures are pretty explanatory. Make paper stencils of the openings you want to close. Each side is different so you'll need 2 stencils. Make them larger than you need. You will trim them later. Clean and de-label a black oil bottle or two. Cut the tops and bottoms off the bottles and slice the remaining plastic down along a corner. This will give you the basis for the covers. Flatten the plastic and lay your stencils on them. Mark, then cut the covers out. Trim to get the best fit. Use the existing fairing screw to secure the top of the cover and tuck the rest of it using whatever screws or fairing trim there is.
http://www.pbase.com/elvin315/image/46753687
http://www.pbase.com/elvin315/image/46753688
http://www.pbase.com/elvin315/image/46753689
Offline gwb1340
« Reply #3 on: August 01, 2011, 07:25:09 PM »
have you used both the oil bottle heat shields and Brian's at the same time?
Offline elvin315
  • Global Moderator
« Reply #4 on: August 07, 2011, 08:18:44 PM »
Neither. I just collect the info and pass it on.
