Author Topic: annoying buzzing noise around 3000rpm  (Read 2719 times)
Offline misterd
« on: January 30, 2012, 04:35:28 PM »
is anyone else having the issue of an annoying buzz around 3000 rpm. cant pinpoint if its the guage cluster or the fairing
Offline krsron
Re: annoying buzzing noise around 3000rpm
« Reply #1 on: January 30, 2012, 04:44:25 PM »
mine was the instrument cluster.  Added some rubber shims on top to get rid of noise.  Rubber was from a old innertube.
Offline Gearhead82
« Reply #2 on: January 30, 2012, 05:09:17 PM »
I've fixed a couple rattles on mine.  The worst and most difficult to track down was my bar end weight.  Didn't matter how tight it was, it always rattled.  I ended up using a little black silicone between the weight and the handlebar and the buzz went away.  Another one was the black plastic triangle underneath the windshield.  I used a little weatherstripping on the underside of it to stop that buzz.
« Reply #3 on: January 30, 2012, 05:13:15 PM »
Joncon11
« Reply #4 on: January 30, 2012, 05:43:46 PM »
Even if there is a buzzing on mine there would be no way I could hear it with earplugs and the helmet on. Besides, 3000RPM comes and goes so fast it wouldn't be an issue anyway ;).
Offline Shoe
« Reply #5 on: January 30, 2012, 06:10:33 PM »
What gear are you in and how fast are you moving when this buzzing occurs?
Eat corn. Drill for oil.
2008 Concours, 2010 Goldwing
Offline Z71
« Reply #6 on: January 30, 2012, 10:38:58 PM »
I had a very annoying buzz on my Suzuki Bandit in a similar narrow RPM range and it was inherent in the fairing design.
So far no such noise on the C14.
« Reply #7 on: January 31, 2012, 03:17:51 AM »
+1 here.
Bar end weights: 1,5 mm washer
Black plastic triangle: weatherstripping on the inside of the lip
...and she is as smooth as they come.  8)
Offline marku8a
« Reply #8 on: January 31, 2012, 09:12:02 PM »
Me too. Glad that you mentioned it and thanks to the others for the recommended fixes. I plan to remove the instrument cluster this weekend to make the display modification...
http://www.zggtr.org/index.php?topic=6597.0
I hope that I can kill the buzz. It makes me crazy!
Mark
2009 C14 Red
