Author Topic: Heli Bars for the C 14  (Read 5569 times)
Offline So Cal Joe
« on: January 28, 2012, 08:19:56 AM »
Re: Heli Bars for the C 14
« Reply #1 on: January 28, 2012, 08:49:05 AM »
I'm probably going to spring for a set this year at some point.
« Reply #2 on: January 28, 2012, 09:57:50 AM »
You should.  We need to get you on the road again.
« Reply #3 on: January 28, 2012, 10:10:08 AM »
It's what I'm hoping for at the moment.
« Reply #4 on: January 28, 2012, 10:45:29 AM »
Agreed! We should all chip in to a fund and buy these for Jim for his bday or something...  :)
« Reply #5 on: January 28, 2012, 11:10:05 AM »
No need for that, but I appreciate the sentiment.
Offline Cuda
« Reply #6 on: January 29, 2012, 03:32:14 PM »
I just bought a 2011  Concours  14,  I'm 57 5'11"  and this is my first bike in 26 yrs ,
I went for a one hour ride last night and I got a hell of a pain near the top of my back spine area! .
What can solve this ? two inch riser? those new Horizon ST bar kit?
I ordered a Corban seat and I was going to wait till that came before I made any other changes but I need to change something with the bars!
I saw a 200+lb black bear run in front of me on a dark two lane road near a rest area that made me nervous , what IF'S started going through my mind :-\
Gods waiting room Naples
2011 Atomic  Silver
Offline vortex2
« Reply #7 on: January 29, 2012, 04:01:19 PM »
I see longer hoses for the brakes, but what about the heated grips on the >'10 models?
« Reply #8 on: January 29, 2012, 05:50:21 PM »
You need to practice.  You can't just jump on a new bike after 26 years and not have some pain.  Especially since you are probably at least in your 40's now.  That is perfectly normal.  Your body will adjust- hopefully becoming stronger and more flexible where needed.  You might need some accessories, but knowing your height means nothing.  Body mechanics are far more complicated than that.  You will have to experiment, pay attention to your body, etc.
« Reply #9 on: January 29, 2012, 06:38:01 PM »
Here is a good thread on riding position
http://www.zggtr.org/index.php?topic=1601.0
Offline philipintexas
    • Phils Farkels
« Reply #10 on: January 29, 2012, 06:50:21 PM »
"You need to practice.  You can't just jump on a new bike after 26 years and not have some pain.  Especially since you are probably at least in your 40's now.  That is perfectly normal.  Your body will adjust- hopefully becoming stronger and more flexible where needed."
I put over 135K miles on my ST1100 and on long days my neck/back would hurt so bad I could barely raise my arms to remove my helmet. I finally made an extender to the bars so I sat upright and it solved the problem. Just supporting the weight of a helmet while leaning forward does it (I think).
« Reply #11 on: January 29, 2012, 07:14:07 PM »
Thanks bro, I somehow missed that thread the 1st time around.  :)
« Reply #12 on: January 29, 2012, 07:41:51 PM »
Well, you left off my last part- sometimes you still need to make changes to the ergonomics of the bike.  But it is my experience that you have to give it some time.  Problems tend to shift around and change... in time, you will know what things are yourself (inability to adjust or adapt) and what things are the machine (simply not designed for your body).
I have such a strange body design that I knew from the start that the stock bike would never work for me- very long torso, short legs and arms, plus I brought RSI/CTS/FMS into the equation.  Still, it is surprising how many things I thought I would need to change did not need changing.  Equally surprising was how much difference and help a tiny change could make (Phil's Wedges are a perfect example).
« Reply #13 on: January 29, 2012, 07:59:05 PM »
U got it, found it by a quick search.  I had forgotten about it.  I am almost there, arms are still just about 1 1/2 too short..
