Author Topic: Best quick disconnect for givi e55 on Phil's rack?  (Read 9991 times)
Offline philipintexas
    • Phils Farkels
Re: Best quick disconnect for givi e55 on Phil's rack?
« Reply #20 on: June 07, 2012, 09:15:03 AM »
Wow, I was thinking 2-3. A trailer wiring harness would only accommodate 4 correct?
« Reply #21 on: June 07, 2012, 09:47:27 AM »
I have a four pin trailer harness on my bike that I use to power my Givi lights.  I love the fact that if I have problems I can stop at any auto parts store to fix it.
« Reply #22 on: June 07, 2012, 10:50:35 AM »
Correct. Trailers generally don't have running lights. They have Left, Right, Brake and Ground.
This is like Admore uses:
http://www.directindustry.com/prod/dongguan-finecables-co-ltd/circular-screw-locked-connectors-70478-579975.html
Offline Grant Borden
  • Its Time To RIDE!!!
« Reply #23 on: June 07, 2012, 04:48:27 PM »
A trailer wired for traditional US made cars/trucks actually has taillight circuit, a return (ground) and a left and right turn signal circuit that is also is used as a brake circuit. To use a 4 wire set up would require a multiplexer in the circuit because of the separate brake circuit on a bike.
Usually can find a small round 5 wire connector at RV dealerships.
1976 BMW R60/6
1980 Vespa P200E
1993 Moto Guzzi Daytona 1000
2008 Kawasaki Concours14
