Author Topic: does dealer have to flash tire press. sensors?  (Read 8967 times)
Offline h2smokin
« on: January 12, 2012, 12:01:11 PM »
Had my tires changed today and they cracked the front sensor. They had a sensor by chance for some reason new in the box so they put it in(they're not even a dealer). I did write the codes but is'nt there some device we could buy and do this stuff ourselves? This sucks having to go dealer for anything. On the upside I got 2 tires mounted, balanced and a brand new sensor for the grand total of $58:)
Offline cablebandit
Re: does dealer have to flash tire press. sensors?
« Reply #1 on: January 12, 2012, 12:26:01 PM »
That sensor and the programming should be free.
« Reply #2 on: January 12, 2012, 12:44:31 PM »
They need to register the new sensor to the bike with a special diagnostic tool.  It's pricey.
« Reply #3 on: January 12, 2012, 01:32:57 PM »
There was one member who bought a KDS3, he's in Venezuela though.
Offline h2smokin
« Reply #4 on: January 12, 2012, 02:07:57 PM »
I'm sure the dealer well want to charge me. It was'nt a dealer who did the install he just had an extra new sensor as he's replaced them before. Have an appt tomorrow for the reflash now.
« Reply #5 on: January 12, 2012, 02:12:57 PM »
Here's some info for you on the process.
« Reply #6 on: January 12, 2012, 03:14:23 PM »
The bike has to be programmed to recognize the sensor(s), not the other way around.
To program the bike, you will need the KDS3 software / hardware package and that is about $700 as I remember. Yes, you can buy that package and do it yourself. Dealers seem to be charging about 1/2 hour of labor to program the bike to recognize new hardware (TPS sensors or fobs).
A Kawasaki dealer would have included the programming in the price of the sensor install but a non- Kawi dealer would not be able to do the programming and most likely not even be aware that any programming is necessary. If the people who broke the sensor are going to take care of the whole problem they (or you) are going to have to take the bike to a Kawasaki dealer and have the service dept. program the bike to use the sensor.
Offline Supatramp
« Reply #7 on: January 12, 2012, 04:53:29 PM »
I have a wheel I bought off a wreck with a sensor, do I need a number, other than what's on the sensor, to get it programed to my bike?
Offline DenverC-14
« Reply #8 on: January 12, 2012, 05:27:53 PM »
My tire guy broke my front sensor. He ordered a new one, and I had to go to a local Kawi dealer to get it to work. I.e. ^ He was a man of his word and paid me for the labor to calibrate it.
Offline So Cal Joe
« Reply #9 on: January 12, 2012, 05:31:40 PM »
The dealer needs the number on the sensor to program it to your bike.
Offline Tactical_Mik
  • Lamh laidir an Uachtar
« Reply #10 on: January 12, 2012, 05:46:49 PM »
You would need the number that came on the plastic wrapping the sensor came in.  The numbers on the body of the sensor are not what is needed to program the bike to "see" the sensor.
T.S.R.
Offline Supatramp
« Reply #11 on: January 12, 2012, 06:13:22 PM »
I was afraid of that, thanks :)
« Reply #12 on: January 12, 2012, 08:34:35 PM »
That is not correct- the number needed to program the KiPass ECU to recognize a TPS sensor is printed on the label on the sensor itself. In fact, it is on the sensor twice, once on the outside and again underneath the cover so even if the outer label is illegible, the cover can be taken off (one screw) and the inside label will be easy to read.
« Reply #13 on: January 12, 2012, 08:35:50 PM »
You can have the bike programmed to recognize the sensor. The number needed to program the ECU is on the label on the outside of the sensor, and again on the inside of the sensor as well.
Offline h2smokin
« Reply #14 on: January 12, 2012, 08:38:12 PM »
I'm glad the # on the sensor is what is needed as I did'nt get the bag when they installed sensor today. Dealer service also mentioned needing # on sensor
Offline Supatramp
« Reply #15 on: January 12, 2012, 09:33:29 PM »
Thanks Brian, I'll check and see which dealers in my area perform this service.
There's a couple used sensors on Ebay, for more than I paid for the whole wheel, tire, rim, and rotor. I was wondering how they could get the prices, they are asking, when I'm sure they don't have the original packaging.
« Reply #16 on: January 13, 2012, 07:40:59 AM »
It is the ignition FOB that has the required number only on the plastic wrapping, not the TPS.
« Reply #17 on: January 13, 2012, 09:27:42 AM »
Apologies for the mis-information about registering.  I got my memos crossed.  I need a better grey matter filing system.
T.S.R.
Offline oldnslo
« Reply #18 on: January 13, 2012, 09:34:52 AM »
  My dealer only charges $18.00 to program the sensor. :thumbs:
happy trails     2016 c14
Offline h2smokin
« Reply #19 on: January 13, 2012, 11:33:04 AM »
It just cost me $34 to get the sensor programmed this morning. I should be good for awile I hope. How long do the batteries in these last approx? Someone needs to do a replacement battery service for these
