Author Topic: LED strips  (Read 2404 times)
Offline jonathan
LED strips
« on: January 10, 2012, 08:10:19 AM »
I saw this LED strip that does stop/turn/tail light functionality at a bike show and plan to add it to the rear of the side bags. At the same show I saw an indentical amber/yellow strip that I could put on the front, but I can't find anyone that sells it. Does anyone know?
http://www.twistedthrottle.com/trade/productview/4645/665
« Last Edit: January 10, 2012, 01:05:42 PM by jonathan »
Offline Cold Streak
Re: LED strips
« Reply #1 on: January 10, 2012, 08:16:32 AM »
I just get the little box with the red x instead of pictures on their website.  I must need an update or something.
Offline ManWorkinghere
    • Avatar database
Re: LED strips
« Reply #2 on: January 10, 2012, 09:08:17 AM »
Weblink is working today....
AdMore Lighting universal flush-mount LED kit for flat sidecases. Also shown: Admore Lighting universal flush-mount LED kit for flat topcases.
Admore's low-profile, universal light kit can be mounted on just about any side case with a relatively flat surface. Each LED light array comes with high strength 3M tape for a quick and permanent installation. These LED light arrays have been designed with the wires exiting from the backside of the array so that no wires are visible after installation.
The mini controller embedded in the main harness fits neatly under your seat or behind the tail light assembly and allows you to connect the light kit to your bike or scooter’s tail light, brake light, and turn signals!
With this kit you receive:
    2 high-intensity LED light arrays (5 1/2" x 3/8" x 1/8" each)
    1 mini controller (with turn signal functionality) embedded in main wire harness
    Wiring, weatherproof quick-disconnect connectors, and detailed instructions
Replaces discontinued part number AML.LED.U.3618.S.TS.
For use on:
    SW-MOTECH Trax aluminum panniers
    Micatech V2 aluminum panniers
    Pelican iM2600 cases
...and other flat-sided hard luggage
Item No: AML.LED.4014.S.TS
Our Price:    $129.00
Re: LED strips
« Reply #3 on: January 11, 2012, 06:14:48 AM »
More stuff at http://www.admorelighting.com/
including LED kits for most Givi boxes and for the 47 litre Kawasaki trunk.
Then there's the Powerbronze Light Flares
http://www.powerbronze.co.uk/5752998/899674/831890/LIGHTS---FIBRE-FLARES---RED.item
