Author Topic: More Reflective tape  (Read 4557 times)
Offline SVonhof
  • 2009 C14
« on: January 05, 2012, 08:04:45 PM »
I recently got a great deal on a Shad SH46 and after riding today, figured I would add some of the reflective tape I have used in the past to help make it more visible. I don't know how visible or reflective the existing stickers/paint is, so I figured more is better.
Before:
After:
After from a little further back:
And from a front view:
I always recommend making yourself more visible to drivers and reflective tape is a really easy way to do that, and it doesn't need to be everywhere and it also can be made to blend in. The tape I used is either silver or black, but reflects light about the same.
Scott
Offline jonathan
Re: More Reflective tape
« Reply #1 on: January 06, 2012, 08:03:51 AM »
« Reply #2 on: January 07, 2012, 02:22:51 PM »
[image]
Ooh, for some reason, I do like that!  Is that yours?  Are they individually-applied stripes?  Did you cut the shapes out yourself?  They look perfect (although it would be a big debate in my mind if it would be better to have the kind that is black/dark color in daylight but reflects at night).
Offline jonathan
« Reply #3 on: January 09, 2012, 07:46:58 AM »
Yes, that is mine. I had some 1" wide reflective tape left over from another project. I made a template to fit the area and then used it as a pattern to cut and place the individual strips. I like it because this works in both daylight and at night whereas the black reflective sheet only works at night. Of course you could put the white stripes on top of the black sheet for double the fun.
