Author Topic: interesting center stand mod  (Read 10343 times)
Offline lt1
  • 2008 C14
Re: interesting center stand mod
« Reply #20 on: December 20, 2011, 11:33:44 AM »
I have never seen a bikes rear tire touching the ground, when on the centerstand unless, you weighted or pushed down the rear of the bike. Then again, What do I know?
Are we reading the same thread?  The comment (park in gear) was based on the ride-off stand, which is the subject of the thread, not the stock centerstand.
Eyes, Brain, Hands.  Repeat.
« Reply #21 on: December 20, 2011, 12:05:05 PM »
That would make sense to me now that you've pointed that out but it's not that hard to use the normal stand and I can ride off that with a push but I could see that shorter legged riders could benefit from the modified stand.
« Reply #22 on: December 20, 2011, 01:06:41 PM »
My bad!  :o  I was wrong! There! I'm man enough to admit it.  :-\ :-[ :-X
But it's like lt1 said "The comment (park in gear) was based on the ride-off stand, which is the subject of the thread, not the stock centerstand."
Offline JetJock
« Reply #23 on: December 20, 2011, 01:46:53 PM »
Unless you weigh 90 lbs dripping wet and have the physique of a soggy pretzel, there is nothing wrong or difficult about the C14's centerstand.
It's easier to put up than my ST1100.
Thing is, most people never read the owners manual where it says quite specifically to have one hand on the luggage rack brace when lifting it onto the CS. Do it properly and it's easy.
« Reply #24 on: December 20, 2011, 04:54:14 PM »
I never use my center stand unless I'm working on the bike...
There is almost no case otherwise where I would consider it stable, safe, or convenient for "normal parking".
Offline marku8a
« Reply #25 on: December 20, 2011, 09:29:35 PM »
I also shift to neutral which seems to make it easier.
Mark
2009 C14 Red
Offline wally_games
« Reply #26 on: December 21, 2011, 10:25:09 AM »
Put your foot on the center stand, push down until both of its "feet" touch the ground, stand on (put your body weight on) the lever and it will come right up. Well, it will if you weigh at least 165 lbs. Anything under that and you man need to apply some lifting muscles.
Offline Tim
« Reply #27 on: December 22, 2011, 04:29:15 PM »
I'm still flipping dizzy from the second vid.  :doublepuke:
Never had a problem getting the 14 on the center stand.
Offline Graffixnfun
« Reply #28 on: December 23, 2011, 09:11:34 AM »
Wow, so your saying the Connie has a center stand?  I guess I need to take a look at my bike........
2009 concours
2006 ninja 650R
2003 victory vegas
Offline ljcorby
  • COG#: 9359
« Reply #29 on: December 23, 2011, 10:06:16 AM »
Yeah, I didn't try it for a while after getting the bike.  Thought it looked too dificult until I actually watched the guy on youtube, I believe, who was doing it with bare feet.  Tried it and it goes right up.   ;D
10 Kawi Concours 14 ABS
