Author Topic: my traction control must be broke  (Read 11085 times)
Offline Zteve
Re: my traction control must be broke
« Reply #20 on: December 18, 2011, 06:32:35 AM »
i gotta get it in some loose sand or wet grass and put it through the traction test, warranty man may be getting my bike finally after all this time.
Better test the ABS too :yikes:
Offline KawiMick
« Reply #21 on: December 18, 2011, 07:29:25 AM »
topic was traction control but threadjacks are always welcome and my TC is broke...oops I meant KiPass bat may be low
Steve,
  You have most likely broken your TC by installing that 190X55 rear tire.  The slightly larger rolling diameter has caused the TC to allow just a bit more speed difference between your front and rear wheels.   :rotflmao:
  I too run a 190X55 and my TC is working great on gravel surfaces and wet pavement in a straight line.
'84 R100RS Pearl White Last Edition
'93 K1100LT Astral Blue Metallic
'96 R1100RT Sine Blue  Tucson,AZ/Santa Paula,CA
'10 C14 Candy Neptune Blue         Born OK the First Time
Offline shokdimn
  • Yeah, I'll trailer it!
« Reply #22 on: December 18, 2011, 09:32:26 AM »
if your front wheel came up and your traction control was on , its broken.
I wonder if this is a fact in every gear—particularly third gear?  ?  Not trying to discredit anyone but; IMO, It would be nice if there were a Big K rep on the forum that could answer this for certain.
From a distance and without warning, relámpago!
« Reply #23 on: December 18, 2011, 12:29:35 PM »
I wonder how that is supposed to work: in the S1000RR traction control and wheelie control are two different features. Me wonders how. Where's Brian?
Offline Kazairl
« Reply #24 on: December 18, 2011, 12:43:09 PM »
They are one and the same on the C14. It is a very simple system. It compares the speed on the front wheel and speed on the rear wheel and that is it. No fancy wheelie control or anything like that. Maybe it got confused. Or the change in tire size makes a bigger difference than one thinks.
 The larger rear wheel turns slower than the front wheel and allows you to wheelie longer before the front wheel slows down enough for the system to detect it.  That's my theory anyways.
Offline DaveO
« Reply #25 on: December 18, 2011, 01:16:22 PM »
it would be easy to find out if tc is working or not. just go try to spin it up on gravel or grass.
I think the whole point of this thread is just that wfl wanted us to know he did a wheelie.
Offline Mister Tee
« Reply #26 on: December 18, 2011, 01:22:02 PM »
I haven't played with turning the TC off, but my bike will power wheelie, at least for very short hops.
« Reply #27 on: December 18, 2011, 01:22:13 PM »
In the spirit of trouble shooting I have a coupla questions.
1.  Did you use a full synthetic oil last oil change?  (Synthetic adds about 50 horse power and some 46 ft pounds of torque)
2.  Did you place your fob in your left or right pocket?  (Right pocket is for touring, left is for squiding)
3.  Did you flip on your 12 volt hair dryer/red neck turbo?
 ;D ;D
Offline rtarp1
« Reply #28 on: December 18, 2011, 03:22:44 PM »
yes the front wheel will come up a tiny bit(it has to for the traction control, to detect it) BUT IT WILL IMMEDIATLY SHUT DOWN YOUR ENGINE, YOU WILL FEELI IT.  IF IT DOESNT DO THAT ITS BROKEN.
SORRY FOR CAPS  WAS ACCIDENT.
Offline DaveO
« Reply #29 on: December 18, 2011, 09:06:59 PM »
and there are people that will pay for this  ?
« Reply #30 on: December 18, 2011, 10:04:56 PM »
1) It is not optional on the US 2011/2012, it is standard equipment, just like ABS.  So you do not "pay for it" (by opting for it) except as part of the price of the bike.
2) It is not designed specifically to stop wheelies, that is just a side-effect.  It is primarily a safety system to keep control, stability, and power in adverse conditions, such as rain, sand, slippery pavement, mud, etc.  For that purpose, people report it works very well.
3) You can disable it whenever you like, from the handlebar controls.  Although, it will default back to "on" again when the bike is restarted.
Offline Wile
  • Kawasaki is Japanese for "Money Pit"
« Reply #31 on: December 19, 2011, 04:59:34 AM »
Me too...
With TC on if I do a power wheelie it comes up a bit but the engine cuts power and it SLAMS back down.
Only a biker knows why a dog sticks its head out of a car window.
Past Bikes...  A bunch.  Current Bikes 1975 Z1 (the rat bike) and a 2010 C14
« Reply #32 on: December 19, 2011, 05:09:46 AM »
I've got you beat on Hayden sigs.  8)
I'm sitting on a goldmine. 8)
He signed your ass?    :o
« Reply #33 on: December 19, 2011, 05:44:44 AM »
Offline cablebandit
« Reply #34 on: December 19, 2011, 07:54:21 AM »
Are you high?
« Reply #35 on: December 19, 2011, 10:06:33 AM »
« Reply #36 on: December 19, 2011, 11:11:02 AM »
It didn't happen unless you have pictures :-X
« Reply #37 on: December 19, 2011, 11:13:59 AM »
Here's my theory. KIPASS is so awesome it can not only read your mind but can read your subconscious thoughts. Steve subconsciously wanted to wheelie the bike so KIPASS shut off KTRC for him. That's the mad powah of KIPASS!!!
« Reply #38 on: December 19, 2011, 11:51:13 AM »
Be careful what you wish for...
Offline rtarp1
« Reply #39 on: December 19, 2011, 12:09:45 PM »
@cablebandit     High as in stoned or high as in the front wheel is high?   No the front wheel is not high , it might make it an inch or 2 at most before throttle is retarded..     When i want to wheelie or ride aggressively  i turn it off..
