Author Topic: Best cruise control  (Read 6798 times)
Offline koblizek8
  • Country: cz
Best cruise control
« on: December 13, 2011, 08:27:11 PM »
Hi can u help me somebody with the cruise control?Which one is realy good Thanx
Re: Best cruise control
« Reply #1 on: December 13, 2011, 08:33:44 PM »
I'm a huge fan of Throttle Meister, simple and easy to use.  Yep, it's a throttle lock, but it can also be used part way on to ease the amount of effort required to maintain a light grip on the noise maker.  I'm still waiting on BDF to come out with his plug and play cruise ;)
Offline DonB
  • Let's Ride
« Reply #2 on: December 13, 2011, 08:38:51 PM »
I put an Audiovox CCS100 on my 2008 and never could get it to work just right, I could not get enough Vacuum----I think, so I switched to the Rostra and thought it worked great
I am about 90% finished with a new install of the Rostra on my 2012
2012 Candy Arabian Red C14 but it's not Red to me
2012 Blue ABS Wing
2011 White Vstrom                               = o&o>
« Reply #3 on: December 13, 2011, 10:59:08 PM »
for my personal use of a CC (resting the wrist, doing super slab, keeping my license), I find the GoCruise (another throttle lock) just about covers my needs. But that's not what you asked. Just ingnore me...  :-[
Offline So Cal Joe
« Reply #4 on: December 14, 2011, 06:46:01 AM »
A buddy put a Audiovox CCS100  on his ST1300 and has trouble keeping a steady speed on an incline. I hear the Rostra is a better unit,
Offline W14
« Reply #5 on: December 14, 2011, 06:55:03 AM »
+ 1 on Throttle Meister, serves my needs.
Offline danvforce
« Reply #6 on: December 14, 2011, 07:51:50 AM »
Rostra works great, just like a car, really not that hard to install.
Offline jayke
« Reply #7 on: December 14, 2011, 09:50:48 AM »
Just to be clear, the Rostra only works on bikes with a VSS (Vehicle Speed Sensor).  The Rostra needs both a
VSS and tach signal to operate.
Older bikes like the C10, KLR etc... without a VSS (Vehicle Speed Sensor) can't use the Rostra.  They need to use the Audiovox (Murphs) CCS-100.
« Reply #8 on: December 14, 2011, 11:01:02 AM »
It does need a VSS but does not need a tach signal. I have installed 2 of them now and they work great.
Offline jayke
« Reply #9 on: December 14, 2011, 11:56:02 AM »
Thanks for the clarification.  I've only helped on a Rostra install.  I've done several Audiovox installs myself.
« Reply #10 on: December 14, 2011, 09:10:18 PM »
I have been chicken, but do have a Rostra on my "wish list", perhaps for next year.  Doesn't look TOO hard to install, although I really do hate the ugly/huge control panel and wish there was something better.
Offline SANDPSYCHO
« Reply #11 on: December 14, 2011, 09:42:09 PM »
Sorry but, “I’ve installed 2 isn’t going to cut it.”
Is there a particular model you have installed?  A Google search shows several different types but the price seems very reasonable.  What all is involved on the install? Did you have to cut into the harness? I'll have more questions later. ;D Pic's?
« Reply #12 on: December 15, 2011, 10:44:30 AM »
The one on my bike was purchased from murphskits.com (whatever model that is). I installed it on my 2010. No cutting into a harness. You do have to splice into 3 different signals, the VSS (vehicle speed sensor), clutch circuit and rear brake light.
The second install was helping a friend on a 2009 also purchased from murphskits (I think). Electrically the install was identical, mechanically the location of the unit was quite different due to the different fairings from the 09 to the 10.
Both installs used the control pad from murphs: http://www.murphskits.com/catalog/product_info.php?cPath=25&products_id=369
Brian from this forum did a fantastic job writing up how to install this on an 08-09. As I have said the location of the unit on a 10 or later has to be different. I chose to put it under the upper right fairing and run the cable across the front of the tank to the left side.
http://www.murphskits.com/catalog/docs/Rostra%20install.htm
I do not have a lot in the way of pics but here is the control pad on the left handle bar. I made an aluminum bracket that attaches under the brake lever bolt (the black paint bubbled and I never got around to sanding it and repainting).
Here is the control cable and the bracket on the left side connecting the cable to the throttle under that fat gray harness. In this pic you can also see the VSS coming out of the top of the case between the 2 bolts on the right side of the pic. You have to splice into that tiny pink wire.
Offline SANDPSYCHO
« Reply #13 on: December 15, 2011, 11:23:49 AM »
Thanks for the info and pic's Rhino.
Going to have to add this to my list.
Offline oldnslo
« Reply #14 on: December 15, 2011, 12:59:50 PM »
      had a rostra on my 09 connie for almost 3 years. works great with no problems.
happy trails     2016 c14
