The Hobby stores have The Brass tube, some you may be able to buy just 1 12" tube. I got a pack of 4 tubes for $4. No epoxy needed, if done right. Use a drill smaller than the tube, you may have to buy that. Instead of fractional, maybe Numbered or lettered. Something .002" smaller than the tube you buy. Then drill straight with a good drill that doesn't have run-out in the chuck/ motor. Step drill it, start 1 size smaller than the final size, then they will fit tight. P.O.C!
