Author Topic: C 14 2010 Battery tender quick disconnect plug  (Read 3566 times)
Offline bombsquad1201
  • Robots know blue is faster
« on: November 26, 2011, 07:09:41 PM »
Howdy Everyone.
I just installed a battery tender plus quick disconnect plug to my 2010 C14.
If you have had the battery compartment open, you may have noticed that the ground from the battery is bolted to the frame.
I bolted the negative lead for the battery tender to the ground on the frame.
Does this sound o k to young guys? Any thoughts? Recommendations?
Thanks for the help.
J.
PS. Jim I have read all the previous post on this subject.
Offline BanditDude
Re: C 14 2010 Battery tender quick disconnect plug
« Reply #1 on: November 26, 2011, 07:44:18 PM »
Any common ground will work equally well.  It'll be fine.
« Reply #2 on: November 26, 2011, 08:03:34 PM »
Sounds ok to us old guys too :-\
Offline gnuse
« Reply #3 on: November 26, 2011, 08:08:06 PM »
"God does not deduct from one's time on Earth, that which is spent in the air."
« Reply #4 on: November 27, 2011, 06:25:32 AM »
50 something is middle age right?
Sounds ok to us middle aged guys too, at least this one.
Offline Motor Head
  • Resurected Concours, $260 Purchase & Counting
« Reply #5 on: November 27, 2011, 07:10:58 AM »
 On my Street Bikes and Cars, I use the 12v power point/ Lighter socket. Make sure it is Hot at all times, of course fused, and put a Male end on the Battery charger. Then it just plugs right in nice and quick. I've been using those Harbor Freight Float Chargers. $5 when on sale, which they are at the moment.
1990 ZG1000 C10
1982 KZ1000 LTD
« Reply #6 on: November 27, 2011, 07:25:32 AM »
If you plan to live to be 100.
« Reply #7 on: November 27, 2011, 07:29:55 AM »
I'm shooting for 105.    8)
« Reply #8 on: November 27, 2011, 07:44:17 AM »
You get a cookie...thanks.
Offline rcannon409
« Reply #9 on: November 28, 2011, 06:05:16 AM »
One advantage of bringing the lead directly off the battery is the plug matches the slime mini aircompressor.  So, in an emergency you can glue all the plugs to your fingers....but you'll still have air available to inflate the tire.
Offline Ga. Cycle Rider
« Reply #10 on: November 28, 2011, 07:52:05 PM »
since some here are discussing lifes longevity, may I suggest this. If given the choice of knowing when you are going to croak, or where you are going to croak. always choose where. Then do your best to avoid the hell out of that place. Its also way better to get older than colder. and how did you get the battery cover off without chewing out the moist-ass cheese cover bolts like I did. I could not believe I was sitting there drilling out a bolt on a 2 week old bike with 400 miles on it. I remember saying to myself...WTF.
Riding big bore in line fours and v-4 hondas and such since 1976. Lost count of the miles, but it is more than 500 thousand. Currently in the garage...1999 vfr800, keeper forever. 2006 klr 650, forest road thrasher, 2011 C-14 ICBM.
