Author Topic: Stuck in alpine tx  (Read 4103 times)
Offline olie
Stuck in alpine tx
« on: November 25, 2011, 06:16:10 PM »
Rear tire has nasty glass cut
Local guy procured a rear tire out of town
Install to  be done tonight or tomorrow morning
Any special tool or instruction?
Forgot manual at home...
Thanks for any help
Olie
13 Blue Connie, 8/4/2013
16 Green Versys 1k
11 Red Vette
Offline Khrome
Re: Stuck in alpine tx
« Reply #1 on: November 25, 2011, 07:08:37 PM »
Hope you get it going, they have a shop there? Your still closer to home than to me...
Khrome 2011 C14...09 Kaw Voyager...08 Yam WR250X...07 Yam FJR...06 Suz M109...04 Yam RoadStar...03 Kaw ZZR 1200... 02Kaw ZRX1200...01 KTM LC4...00 Kaw KLR 650...99 Kaw C10...98 Kaw ZRX 1100...94 Kaw Zephyr 750...85 Kaw 454LTD...79 Honda XL250S
Offline dras
  • The Invisible Man
« Reply #2 on: November 25, 2011, 07:29:13 PM »
Just be sure to tell them about the TPMS sensors in the tires. Some measure of care is needed to avoid damaging them.
Never get too busy making a living that you forget to make a life.
Offline KawiMick
« Reply #3 on: November 25, 2011, 08:25:34 PM »
Thanks for any help
Olie
•Tighten:
Torque - Rear Axle Nut: 127 N·m (13.0 kgf·m, 94 ft·lb)
Caliper Bracket Bolt: 64 N·m (6.5 kgf·m, 47 ft·lb)
'84 R100RS Pearl White Last Edition
'93 K1100LT Astral Blue Metallic
'96 R1100RT Sine Blue  Tucson,AZ/Santa Paula,CA
'10 C14 Candy Neptune Blue         Born OK the First Time
« Reply #4 on: November 25, 2011, 08:32:52 PM »
•Tighten:
yeah, like he is likely to have a torque wrench handy.... ???
Gutentight works fine.... ;) just make sure to put a cotter pin back in, or a nail, or something, to keep the nut on.... ;)
Offline KawiMick
« Reply #5 on: November 25, 2011, 08:36:21 PM »
I'm assuming he means a local shop.......  hopefully they have some tools. :nuts:
Offline olie
« Reply #6 on: November 26, 2011, 07:30:39 PM »
 it was a nightmare but at least I am back on the saddle...
overpriced tire from Odessa :o
car shop refuse to use their machine to break the bead >:(
finally we found an old machine  ;)
after a few scratches   :'(
bike was rolling ;D
16 Green Versys 1k
11 Red Vette
Offline Z71
« Reply #7 on: November 27, 2011, 08:17:54 PM »
Come on guys, most of us never torque the rear caliper bracket bolt anyway, so you expect someone to do it as an emergency repair?  I can see torquing the rear axle nut, but even then, there is the cotter pin to keep it from backing off.
« Last Edit: November 28, 2011, 08:38:14 AM by Z71 »
« Reply #8 on: November 27, 2011, 09:56:36 PM »
Come on guys, most of us never torque the rear caliper bracket bolt anyway, so you expect someone to do it as an emergency repair?  I can see torquing the rear axle nut, but even then, there is the cotter pin to keep it from backing of.
^^^^that 100%.
Offline olie
« Reply #9 on: November 28, 2011, 08:48:18 AM »
yeap, as long as you clear the cotter pin you are in good shape. That's what  it was done.
16 Green Versys 1k
11 Red Vette
Offline Arata
« Reply #10 on: November 28, 2011, 10:52:20 AM »
So I'm weird that I carry a torque wrench on trips when I can?
2014 V Strom 1000
2008 C14
2004 ZRX1200R
1993 GSXR 1100
« Reply #11 on: November 28, 2011, 11:25:45 AM »
Yes.
Offline Z71
« Reply #12 on: November 28, 2011, 05:06:22 PM »
Is it calibrated before each trip?   ;D
Offline Arata
« Reply #13 on: November 30, 2011, 08:53:30 AM »
no, that's just crazy!
2014 V Strom 1000
2008 C14
2004 ZRX1200R
1993 GSXR 1100
