Ok folks, I've posted previously about this, and it is happening again. My front brakes are dragging. At some point I used them and now they don't release. I can hear them rubbing at highway speeds. I grab a hand full, and then release a couple of times, but nothing. They continue to drag. By dragging I am saying that when I get home, I put the bike on the center stand and give the front wheel a spin. It won't turn more than about 1/8 of a turn on it's own. I am convinced that this is how my first set of rotors warped. I've had them (both) replaced and all has been well until now.
The last time they did this, I took them apart as soon as I got home (this is about 1500 miles ago) from my ride. I cleaned them with brake cleaner and a tooth brush. I cleaned all around the pistons and pucks, scrubbed all the mounting gear and keepers. After all that, put it back together, and it all started again a thousand miles later.
To be honest, I don't 'regularly' clean them unless I have a problem like this. I find it unacceptable to 'HAVE' to clean my brake calipers so regularly. What gives? Anyone else noticing any thing like this?
edit: I never did find a 'cause' of the failure to release. I just cleaned them all up, and reassembled them, and they worked.
