Author Topic: Front TPS sensor low battery  (Read 2829 times)
Offline Awaz
« on: November 08, 2011, 02:17:49 PM »
Lately, I have been getting this message about front TPS battery low. I get the message on cold mornings or evenings, but it goes away after I rode for a few miles. Appears when the tire warms up, the message goes away. Is this an indication of getting the battery replaced? Or nothing to worry about?
2016 Ducati Scrambler
2008 C14
Re: Front TPS sensor low battery
« Reply #1 on: November 08, 2011, 02:58:07 PM »
It is a common, known situation and nothing to worry about. The battery inside the TPS sensor will show a low voltage when first used in cooler / cold weather but the voltage will and come up after the sensor has been active for a few minutes and the warning will clear itself. You can ignore it or have the sensors replaced under warranty as you choose.
If you do a search there is a lot of info. on this subject.
Offline Scaffolder
« Reply #2 on: November 08, 2011, 05:14:21 PM »
Some people have even timed the warranty work at the perfect time. Like when you need new tires. You might get them to install for free.
Joel from Maine.
