Author Topic: Bike blows smoke when I upshift  (Read 7548 times)
Offline Spanky
« on: November 05, 2011, 08:38:07 PM »
I was riding today with two other c-14's and my buddy Cablebandit told me that my bike was blowing smoke out of the exhaust every time I upshifted. The motor still runs strong - just blowing some smoke. I have the full system from fuel moto installed, the map Jamie loaded when he shipped the pc, no flies. Any idea what could cause this? JamminJerry said it may be loose or tight valves? I hope it is something simple like that. I have just over 30k miles on her so she is due for service, but I would like some input from the mechanical genius's on this site so I can ask the correct questions when I talk to the mechanic. Has anyone else had this happen? If so, what was the cause?
Thanks in advance for any input.
Offline gonzosc1
Re: Bike blows smoke when I upshift
« Reply #1 on: November 05, 2011, 09:14:57 PM »
what color smoke. black would indicate running rich, gray/blue would indicate oil.
Offline Spanky
« Reply #2 on: November 05, 2011, 09:32:16 PM »
Grey/blue and was told it smells like oil.
« Reply #3 on: November 06, 2011, 06:01:39 AM »
Not good.
« Reply #4 on: November 06, 2011, 06:05:27 AM »
The cause could be worn valve stem seals or excess piston ring clearance.
Offline Motor Head
  • Resurected Concours, $260 Purchase & Counting
« Reply #5 on: November 06, 2011, 06:48:35 AM »
 FNG to the forum, but not to bikes/ engines.
Start first with a compression test, followed by a leak down test. That will give you a very good indication of your engine condition. Worn oil rings or valve stem seals/ guides won't show on either test, but you will be better informed on overall condition. You may find low compression, then with the leak down test, where it is going. Then you can decide/ save $ for the work. ;)
1990 ZG1000 C10
1982 KZ1000 LTD
« Reply #6 on: November 06, 2011, 09:15:42 AM »
For what it's worth: When I bought my 99 VFR it had 11,000 miles on it and at first my riding buddies would tell me the exact same thing, it would blow a puff of blue/white smoke on upshifts.  Sometime later it quit and now, 125,000 miles later it still runs as strong as ever and uses no oil at all between 6000 mile changes.
Offline Spanky
« Reply #7 on: November 06, 2011, 09:45:03 AM »
Good to hear! I am calling to schedule service tomorrow. Hopefully it is something that can be fixed easily, if not, thank goodness for the warranty! I don't think it is anything too bad, it pulls very strong and does not make any wierd noises, but I will let a pro check it out.
Thanks again, I appreciate the input.
Offline Motor Head
« Reply #8 on: November 06, 2011, 10:03:49 AM »
 You would probably have 1 spark plug with residue on it, more carbon deposit from the oil.
 Could be a Valve stem seal that got damaged when installed, or an Oil ring Expander that has the ends over-lapped, or the ends that butt together, one broken. Or just the rings gaps are lined up, instead of staggered on the oil ring.
 Just possibilities. Any sign of oil in the Air Cleaner housing?
1990 ZG1000 C10
1982 KZ1000 LTD
Offline Spanky
« Reply #9 on: November 06, 2011, 03:26:35 PM »
I didn't check the air cleaner housing. I cleaned my air filter about 3k miles ago and I didn't see anything, but at that time I was not looking for oil either. Time for a real mechanic to service it anyway, so we will see what they come up with.
Thanks for the help, I appreciate it.
« Reply #10 on: November 07, 2011, 06:27:10 AM »
It is probably nothing important and just shedding some oil that has collected in the head. Changing the brand / weight of oil used might stop the engine from doing that.
Usually, smoke that appears when the throttle is closed, and a high- vacuum condition is created, is the result of loose valve guides / seals and oil is getting sucked into the intake. Bad ring seal on the pistons usually results in producing smoke when hard on the throttle but not when the engine is under little or no load (such as when you close the throttle to shift). Unfortunately neither a compression test nor a leak down test will detect loose valve guides because both tests are done when the valves are closed.
As someone already said, check the spark plugs for any signs of fouling. If they, or one, have excessive carbon build- up, it might be time to check the valve(s) stem(s) for proper clearance and the valve seal(s). Another sign of loose and leaking valve stems is wet oil accumulated in the exhaust ports or very early in the exhaust system but that only works if the bike has been ridden relatively lightly so as not to heat that oil up enough to dry out and cook off. Valve stem clearance is a manual check, done by trying to rock the valve in the valve guide and watching the movement with a dial indicator. Any of that would be covered under warranty if the bike is still under warranty, and perhaps even if it is not- valve guides should absolutely not fail in 30K miles.
Again it is probably nothing though and unless there are other symptoms or excessive oil consumption, and the engine runs correctly and strong at all RPM’s, I would probably ignore it once the bike has been through major maintenance and everything looks fine.
Offline Spanky
« Reply #11 on: November 07, 2011, 02:14:18 PM »
Thanks for the information Brian! I am going to have the valves adjusted and everything else that goes with the 30K service so new plugs will be installed and I will make sure the mechanic checks the valve stem and valve seals. The bike is still under warranty and I purchased the extended warranty from the great deal I believe Man of Blues set up for us with his dealer in Virgina, so I am covered for several more years  ;).
Thanks for your help.
David
Offline JamminJere
« Reply #12 on: November 30, 2011, 04:05:18 AM »
So, Spank.... How did you make out with your service?  Any smoke seen on Sunday?
JJ
Offline cablebandit
« Reply #13 on: November 30, 2011, 07:22:53 AM »
The only smoke I saw was when he hammered it on a straightaway.  No shifting smoke at all now.
Offline gnuse
« Reply #14 on: November 30, 2011, 08:25:32 AM »
Let the mechanic know what he is looking for and ask him to let you see the findings such as plugs, compression test, etc. It would be nice to share the results for the benefit of all.
"God does not deduct from one's time on Earth, that which is spent in the air."
Offline IBA42214
« Reply #15 on: November 30, 2011, 08:59:27 AM »
I'm new here but, I'm surpised no one said it had to be Kipass  ;)
That seems to be the common theory on everything.
2008 C14
2007 Nomad
IBA# 42214
Offline Z71
« Reply #16 on: November 30, 2011, 09:23:53 AM »
Just curious, wouldn't unauthorized modifications you have done to the bike void your warranty if Kawasaki finds out:?  Every time you modify something under warranty, be prepared to give up your warranty coverage.
Offline gnuse
« Reply #17 on: November 30, 2011, 12:14:20 PM »
I can hear it now.......the non-stock fuel system provided excess fuel flow into the cylinder which washed the expected oil lubrication from the cylinders and caused the piston rings to wear prematurely.  :(    .....or something to that effect.
Offline cablebandit
« Reply #18 on: November 30, 2011, 01:14:32 PM »
Magnuson–Moss Warranty Act...learn it, love it.
His exhaust valves were out.  Now they're not.  Problem solved.  ;D
« Reply #19 on: November 30, 2011, 02:32:09 PM »
His exahust valves were 'out'? Like out of the engine, sitting on a bench and letting oil leak down through the valve guides?  ???
Could you expand on that a bit? I am not following how exhaust valves might be 'out' and cause a high vacuum oil loss?
