Author Topic: Throttle Tamer and Heated Grips on '09 Connie  (Read 8404 times)
Offline roadie
« on: October 31, 2011, 06:38:11 PM »
Well finally had a a couple hours to replace throttle tube with Throttle TaMER, and install some heated grips and new grips.  Here are some photos if anyone is interested:
Throttle tamer:  installed super quick...took a couple minutes to readust the throttle cables, but not too difficult.
Heated grips: pretty simple as well...went like clock work.  Hot without gloves, but don't penetrate my T-5 gloves to well....lets see how they hold up in super cold weather.
New Throttle Tamer Installedanother Pic of Throttle Tamer
Hole Drilled for switch (13/16")These cables were run months ago and coiled up waiting
Extra cables run to Fuze-Block coiled and readySwitch installed
« Last Edit: November 02, 2011, 05:05:40 PM by Roadie »
Will
Offline ninjawarrior1400
Re: Throttle Master and Heated Grips on '09 Connie
« Reply #1 on: November 02, 2011, 03:04:56 PM »
I want to install the Throttlemaster on my 2010 with factory heated grips but am afraid to try to remove the stock grips for the rework for fear of damaging the stock heating elements...
Can they be safely removed using an air compressor??
Advise....
Ninja
Ninjawarrior
« Reply #2 on: November 02, 2011, 03:32:17 PM »
Why would you have to remove the grips to install the TM?
Offline Tactical_Mik
  • Lamh laidir an Uachtar
« Reply #3 on: November 02, 2011, 03:44:21 PM »
They are talking about replacing the throttle tube with a throttle master tube not replacing the bar ends with a throttle meister.  There is your difference.
T.S.R.
« Reply #4 on: November 02, 2011, 03:58:21 PM »
Op installed a Throttle Tamer throttle tube. If Ninja is just wanting to install TM it should be done by just rolling about 1" of the grip inboard, as per instructions, to allow for installation.
« Reply #5 on: November 02, 2011, 04:07:09 PM »
Well obviously there are too many tm's in this thread.  :)
T.S.R.
Offline roadie
« Reply #6 on: November 02, 2011, 04:19:48 PM »
Yeah my fault. I did not install a meister I installed a tamer.
Will
Offline roadie
Re: Throttle Tamer and Heated Grips on '09 Connie
« Reply #7 on: November 02, 2011, 05:06:47 PM »
sorry dudes.. JV move on my part...fixed the title...
Ninja:  here's a recent thread on glue/air/etc on installing/removing grips, hope this helps:
http://www.zggtr.org/index.php?topic=5089.msg59519#msg59519
Will
« Reply #8 on: November 02, 2011, 05:10:39 PM »
I'll put my glasses on next time. :)
Offline roadie
« Reply #9 on: November 02, 2011, 05:11:35 PM »
yeah, surprised no one clowned me for that one.  :D
Will
« Reply #10 on: November 02, 2011, 05:18:08 PM »
So Roadie, have you got any miles on the Tamer yet?
Offline roadie
« Reply #11 on: November 02, 2011, 05:33:51 PM »
about 200 hundred.  gotta admit...i'm too much of an ape to notice any discernible difference.  Not sorry I installed though...I'll see if I soon appreciate more.  You use?
Will
Offline Caffeinated
« Reply #12 on: November 03, 2011, 06:00:39 AM »
Advise....
Ninja
Yes....see this thread.... http://www.zggtr.org/index.php?topic=439.0
My next purchase is a G2 Throttle Tamer!
2012 Black Concours 1400
« Reply #13 on: November 03, 2011, 06:07:26 AM »
Yes. I noticed a slight difference in the on/off throttle engagement but the biggest thing I noticed was the smoothness of the actual turning of the throttle tube. The bushings eliminate metal to metal contact and the associated drag.
Offline Caffeinated
« Reply #14 on: November 03, 2011, 06:11:38 AM »
Will, you get your tamer direct from G2 or from some other source?
Offline roadie
« Reply #15 on: November 03, 2011, 06:26:55 AM »
Direct. took seconds to pop on.
Will
