Author Topic: Rebuild of my C14  (Read 42679 times)
Re: Rebuild of my C14
« Reply #80 on: December 11, 2011, 05:39:44 PM »
Mmmm.... Muzzys and Kawi go together like steak and potato.  :P :thumbs:
Offline rcannon409
« Reply #81 on: December 11, 2011, 06:16:40 PM »
Earlier I was not so sure about the black bags, but they sure look good now.
« Reply #82 on: December 11, 2011, 06:21:54 PM »
Thanks for the comments, I am pretty happy with how it turned out, but I still have a little more left to do.
Still on the "to do" list:
Fork revalve from Ohlins
powdercoat wheels
black out the rear grab handles and risers
figure out why my a/f ratio isn't showing up from the autotune {scratches head}
Offline Arata
« Reply #83 on: December 11, 2011, 06:39:44 PM »
Make sure you have the little rubber plug In the autotune to activate it.
2014 V Strom 1000
2008 C14
2004 ZRX1200R
1993 GSXR 1100
« Reply #84 on: December 11, 2011, 06:43:31 PM »
Can you elaborate?  I don't recall reading about the "little rubber plug".
Offline Arata
« Reply #85 on: December 11, 2011, 06:48:03 PM »
There should be a small rectangular plug that you have to install in the autotune open port. (the one you don't have the cable plugged in at)
2014 V Strom 1000
2008 C14
2004 ZRX1200R
1993 GSXR 1100
« Reply #86 on: December 11, 2011, 06:48:51 PM »
Ok, I will double check that.  Thanks.
« Reply #87 on: December 11, 2011, 07:31:38 PM »
Worked like a charm.  I forgot to plug that open port and I even wondered the other day why they included two extra four pin, black plugs. All is good now, thanks.
« Reply #88 on: December 11, 2011, 09:35:45 PM »
Jeremy, does your local shop have a dyno? Have you tought about doing a custom map with your setup since it's a little rare? I gained a couple extra ponies but more important flat lined my A/F with a custom map done on the dyno...
Blue line is the drop in map, red line is the custom map done on dyno.
« Reply #89 on: December 11, 2011, 10:16:19 PM »
Hey, JD, how come you have someone elses bike in yer avatar? ;)
Looking good, starting to look like a Soldiers bike ;D  If you had a pair you'd pinstripe the raised portions on the bags pink 8)
Offline tyler1015
« Reply #90 on: December 12, 2011, 06:20:31 AM »
looks great JD!
« Reply #91 on: December 12, 2011, 06:33:55 AM »
I don't have any shops close by that will touch a bike unless it is a Harley.  I will be patient and try to get to a dyno in STL or KC.
@SOP:
You know me to well, pink would set if off nicely.  I was also thinking about pink tassles and LED's.   ;D
« Reply #92 on: December 12, 2011, 06:14:29 PM »
AutoTune and Muzzy are working well.  The front end felt very light today, I could feel the extra power.  And it sounds soooo good.   8)
Thanks for the PCV maps, SOP and Arata!
Excavator
« Reply #93 on: December 12, 2011, 07:08:37 PM »
Looks like you've been busy. I like the way it turned out, it looks really good. If you get tired of the Muzzy just let me know.  :thumbs:
I don't see the pink bar end tassles in the photos........special order?
Offline tyler1015
« Reply #94 on: December 14, 2011, 07:57:22 AM »
Hey Zg just asking. Is 147 low for doing a full exhaust? does the dual setup not give you the power the 4 into 1 does? When I dyno my bike I am hoping that the bike will have more then that.
« Reply #95 on: December 14, 2011, 09:05:02 AM »
Any dyno can throw a number, it is all up to the operator how everything is set up.  I bet ZG's bike could put down 150+ on another dyno, it is the before and after dyno sheets that show how much of an improvement was made.  IIRC Wanderlust (Aussie) posted a dyno sheet from his dual Muzzy setup that was somewhere around 162 hp.  I don't worry about numbers very much, it is a tool and that is it.  Just my 2 cents.
« Reply #96 on: December 14, 2011, 11:19:15 AM »
+1 to Jeremy's point, the number that means the most is what you gained on the same dyno in same conditions etc. I did a base line run on this same dyno just prior to going to a full system and got 133 with stock header and Muzzys slip-on, going to a full Muzzys system, PCV, flies out, and K&N gained 14 hp. Gaining 14 is more than a 10% gain and pretty spot on for going to a full with PC etc. Temps, humidity, calibration of the dyno etc all change what the numbers will show, I could probably show 160 on somebody else's dyno but then again that dyno would also probably show stock at 148, which we all know is wrong... The Kawi specs show the stock Connie at 133, and that's what mine did on the base line run prior to going to full system run, so I feel pretty confident in the dyno being done accurately on my Connie.
« Last Edit: December 14, 2011, 01:10:27 PM by ZG »
Offline Arata
« Reply #97 on: December 14, 2011, 11:20:03 AM »
I agree about dyno numbers.
I think most are a bit optimistic, to make the customer happy.
It's the difference that counts, not the number.
2014 V Strom 1000
2008 C14
2004 ZRX1200R
1993 GSXR 1100
« Reply #98 on: December 14, 2011, 11:27:46 AM »
Tyler,
Here's my base line run showing the 133 stock prior to going to a full system...
Offline tyler1015
« Reply #99 on: December 15, 2011, 08:19:57 AM »
Understandable about the measure. Was just picturing the fuel moto site where they had a increase of horsepower that was like 24HP. With ZG's it was around 16 hp. So thats why I was asking. Just wondering if the dual pipes didnt give the HP increase like the 4into1 did.
