Author Topic: Rebuild of my C14  (Read 42696 times)
Re: Rebuild of my C14
« Reply #40 on: November 15, 2011, 04:24:58 PM »
I'm not saying I'm gunna run out and paint mine like this, but as a fix to a very scratched up set of plastics, its a great alternative.
Excavator
« Reply #41 on: November 15, 2011, 04:32:40 PM »
I think it would look good on the whole bike, the only drawback would be that it's permanent (striping would require a jackhammer) but that product will outlast the life of the bike anyway. I wonder how that texture would look painted over in a bright color...maybe kawi green.
Flathead
« Reply #42 on: November 15, 2011, 07:26:24 PM »
Looks great JD!
Offline v10killer
« Reply #43 on: November 16, 2011, 07:17:33 AM »
I like the bedliner idea. That solves alot of chips scuffs  and scratching issues, I'll keep that one in mind as i rack up miles on mine. Thanks for updating us I'm still learning a bunch about the c14. Though I do think a copper or green with the black would look really good also. But have to admit I too love a sleeper.
Offline Arata
« Reply #44 on: November 16, 2011, 08:09:23 AM »
The bedliner stuff will chip off under the right (wrong) circumstances.
I've been using it on my fork lowers on the ZRX for a while.  It does hold up better than paint though.
2014 V Strom 1000
2008 C14
2004 ZRX1200R
1993 GSXR 1100
« Reply #45 on: November 16, 2011, 09:25:47 AM »
Maybe on metal, but on plastic it seems to stick like snot.  I messed up a spot on my lower fairing and it was a chore to smooth it down to recoat it.  Seems to be very durable, but I will see how it goes once I get back on the road which should be in the next couple of days.
Offline Arata
« Reply #46 on: November 16, 2011, 09:52:47 AM »
It does look good!
Best wishes on the rebuild of both you and your C14
2014 V Strom 1000
2008 C14
2004 ZRX1200R
1993 GSXR 1100
« Reply #47 on: November 16, 2011, 03:19:56 PM »
Are you sanding it thoroughly first?
Offline Arata
« Reply #48 on: November 17, 2011, 09:00:09 AM »
Yes sir, proper prep.
Honestly, it's too much up close riding with my hoolie bros using sticky ass tires.
2014 V Strom 1000
2008 C14
2004 ZRX1200R
1993 GSXR 1100
« Reply #49 on: December 07, 2011, 06:54:42 PM »
I have my bike stripped...............again.  I am going to be installing the full Muzzy exhaust and finishing up the AutoTune.  I have it wired up and just need to get the bung welded to the midpipe. I installed the Murphs shifter bearings and plugged the fresh air tube going to the pair valve.  All I will have left after tomorrow is putting on fresh rubber, powdercoating the wheels, and sending the forks to Ohlins.
« Reply #50 on: December 07, 2011, 07:02:05 PM »
Nice progress Jeremy!  :chugbeer:
Are you doing the wheels black or something else, I think you were debating on other colors awhile back?
« Reply #51 on: December 07, 2011, 07:10:39 PM »
I am going with black, either gloss or satin.
« Reply #52 on: December 07, 2011, 07:11:28 PM »
Nice!  8)
Offline tyler1015
« Reply #53 on: December 07, 2011, 07:34:51 PM »
Jd can't wait to see what happens with the exhaust. Rembering if u need help hit me up. Even give me a call if u need anything
« Reply #54 on: December 08, 2011, 04:19:34 AM »
I really hate to see you slowing that fast silverdammit bike down with the slower black wheels.
« Reply #55 on: December 08, 2011, 07:40:11 AM »
My wheels are already black so it won't be any slower than it already is.  Plus, slow isn't a bad thing for me right now.
« Reply #56 on: December 08, 2011, 08:00:01 AM »
 :thumbs:
« Reply #57 on: December 08, 2011, 06:10:10 PM »
I got the Muzzy installed today, and it looks great........ to me.  I was pleasantly surprised that the exhaust came with an O2 bung already on it.  There is no mid pipe mount and the muffler mount was done by making an offset bracket.  All in all it was fairly simple.  My biggest problem was getting the exhaust gaskets to stay put.  I ended up using a dab of grease to hold them while I slid the header into place (hopefully it won't smoke for to long  ;D).  Here is a picture of the bracket that I made.
Total weight savings is about 24 pounds compared to the stock exhaust (including the header).
Plenty of room between the can and the pannier.
Excavator
« Reply #58 on: December 08, 2011, 06:28:48 PM »
Looks great. Bet it sounds good also.  8)
« Reply #59 on: December 08, 2011, 06:31:02 PM »
Recently I had been thinking about putting a zx-10 front fender on but I like the protection the stock fender gives the forks and radiator (I also have a Murphs fender extender).  So I decided to hack up the front fender to make it a little more streamlined in the front.
Here is pic after my first trim, the final cut is the pen marking on the masking tape.  I will post up some finished pics tomorrow after the bedliner is dry.
