Author Topic: Gafler SST brake lines  (Read 3611 times)
Offline SVonhof
  • 2009 C14
« on: October 26, 2011, 08:02:27 AM »
How many have them or have used them? I am a member at Pashnit.com and got a newsletter that they are going to be having a sale on the Gafler brake lines where you get the rear brake line for free (starting on Nov 1).  I think you need to be a member of the Pashnit forums, but I am not positive.
So, what do you guys think? Worthwhile to do? I have had 4 different bikes, each one has gone to 30k+ miles and each was about 10 years old when I sold it and moved on, and they each had the original brake lines with no problems.
BUY FRONT – GET REAR FREE. Yep. Free.
Order a set of FRONT Steel-braided Brake lines for your motorcycle, and we’ll throw in the matched REAR Line FOR FREE.   AND we’ll even ship it for FREE (inside USA). Upgrade your order to custom color lines? That’s FREE too! (Needs to be a matched set for the same bike.)
FREE Specials like this are RARE!  Likely another year until we can offer this sale again once it expires 11/30.
STARTS NOVEMBER 1, 2011. Runs just 30 Days. Sale ends Nov 30th.
FREE BUY NOW LINKS WILL BE ADDED on 11/1/11. Get your order in first on Nov 1.
Look up your Part Numbers:
http://www.pashnit.com/product/galfer/brake_lines.html#top
Scott
Offline philipintexas
    • Phils Farkels
Re: Gafler SST brake lines
« Reply #1 on: October 26, 2011, 08:16:51 AM »
I replaced mine with Galfer SS lines, not because of any problem with stock, but because I needed longer lines. I cannot tell any difference in performance and I thought the stock lines were as good as you can get.
Offline roadie
« Reply #2 on: October 26, 2011, 08:31:11 AM »
But I bet it looks super schweet with the braided metal jacket.
Will
Offline SVonhof
  • 2009 C14
« Reply #3 on: October 26, 2011, 09:17:31 AM »
Phil, I assume you needed longer lines because of bar risers?
Scott
    • Phils Farkels
« Reply #4 on: October 26, 2011, 09:30:24 AM »
SVonhof: Not riser blocks, I made my own "extenders" and they required longer hoses, and re-routing of the throttle cables behind the R. fork. As you can see I went with black hoses.
Offline SVonhof
  • 2009 C14
« Reply #5 on: October 26, 2011, 11:37:57 AM »
Interesting Phil. And you don't sell these new riser extenders?
Scott
« Reply #6 on: October 26, 2011, 05:54:37 PM »
I put some on the front because I ruined the OEMs. They do look good but I can't tell much if any difference in braking performance.
Offline Gsun
« Reply #7 on: October 26, 2011, 07:58:06 PM »
Phil - what length did you get? I bought a set of these from a forum member and need longer lines. And, by the way, the extenders are great! I can go way longer in the saddle with them.
    • Phils Farkels
« Reply #8 on: October 27, 2011, 10:33:43 AM »
Gsun :
I purchased a set +4" over stock. I have 4" extenders and have plenty of slack. They worked for 3" also but I had some excess slack to contend with. Unfortunately they added some length to the front wheel cross over line and it is difficult to hide slack in that hose. Use the stock cross-over line if you can.
