They quoted $60 to $240. This one has a bad shaft and lower bearing so is probably a $240. I would actually like to try a 1" shorter shock so would not want to spend that much on this one.
The nitrogen charged part is not what would be expected. It has a rectangular bladder that looks like a small inflatable pillow. The schrader valve is sealed to the bladder. The bladder is installed from the inside of the shock and sits on the side between the cartridge and the shock body.
