Author Topic: which fairing parts to remove to check header nuts?  (Read 4952 times)
Offline h2smokin
« on: October 05, 2011, 04:10:04 PM »
I'm gonna check the header nuts for looseness since this seems to be common. Which fairing parts need to come off? I've looked at the manual and this thing is like a jigsaw puzzle and I have'nt done it before. Just looking for a heads up on the order to do it maybe. I've heard a metallic type rattle which is why I want to check things as well as any other nuts and bolts. Thanks
Offline Freddy
Re: which fairing parts to remove to check header nuts?
« Reply #1 on: October 05, 2011, 05:54:49 PM »
Well, you have to start at the top and work ya way down.  It's a bit fiddly until you see how the panels clip together after the screws are remover.  Just don't force anything.
If you have the appropriate 3/8 drive tools the header nuts can be tightened from under the bike without removing anything - I've done it a couple of times
Offline h2smokin
« Reply #2 on: October 05, 2011, 06:29:29 PM »
i do have swivel setups for the drives maybe i will try that although it would be good to know how to remove them. Did you use only 3/8 or did you need 1/4 drives as well?
Offline h2smokin
« Reply #3 on: October 05, 2011, 09:27:55 PM »
well 2 out of the 3 i checked tonight were loose, check the rest in the morning. Odds are there will be more. thanks again
Offline Freddy
« Reply #4 on: October 06, 2011, 12:58:55 PM »
I used only 3/8 drive
Offline Mister Tee
« Reply #5 on: October 06, 2011, 01:02:18 PM »
Maybe I have big hands or something but even with the side fairing off, I couldn't get past the #1 header even with a 3/8 inch drive and a u-joint.  Well I could physically get the socket on the outer #2 bolt but I couldn't tighten it with the u-joint due to the angle.
Maybe going in from the bottom would work out better.
« Reply #6 on: October 06, 2011, 01:11:00 PM »
I take off the fairing sides, remove the front wheel, and loosen up the rad.  I get in fine after that.  May be overkill but it works for me.
Offline h2smokin
« Reply #7 on: October 06, 2011, 05:23:03 PM »
I got to 6 out of the 8 bolts and 4 of those were loose. the inner 2 are a bear and I gave up for the day. Try again tomorrow on them. As for fairing removal avoiding it at all cost but have to do it someday. Thanks
Offline gonzosc1
« Reply #8 on: October 07, 2011, 01:58:33 PM »
I had to remove side and lower fairings. removed all rad bolts and just pushed the rad forward an inch or so. hoses hold rad up just fine. socket and wrench fit in left side to get the first pipe, after that had to use extensions and swivel and come up through the bottom of the pipes to get the angle.
« Reply #9 on: October 08, 2011, 06:37:03 AM »
Jim is right. I tried it with plastic on and thought all were tight. A few weeks later when I had plastic off for valve adjust I rechecked and several were still loose.
Offline texrider
« Reply #10 on: October 12, 2011, 06:34:51 AM »
I can get to all of the header nuts from the bottom side openings, using a 1/4 drive 12mm flex socket on a couple long 1/4 extensions.  :)
2014 Valkyrie
Offline Freddy
« Reply #11 on: October 12, 2011, 12:51:00 PM »
Yeah but you won't get em tight.
Offline texrider
« Reply #12 on: October 12, 2011, 06:23:06 PM »
Next time, try clock-wise.  8)
2014 Valkyrie
Offline Freddy
« Reply #13 on: October 12, 2011, 07:48:52 PM »
« Reply #14 on: October 13, 2011, 04:13:47 AM »
