Author Topic: Passenger backrest help  (Read 4593 times)
Offline AirplaneTim
« on: October 02, 2011, 08:05:51 PM »
I've got a Givi box with the backrest pad on it, but my wife isn't a fan of it.  She says it hits her too high in the back and feels like it's almost pushing her to lean forward.  She says she thinks something a little lower that will rest as a lumbar support would be better.  Anyone got any suggestions for what I can do to accomodate her a little better?
Re: Passenger backrest help
« Reply #1 on: October 02, 2011, 08:53:47 PM »
Mama likes the Corbin with backrest here...  :thumbs:
« Last Edit: October 02, 2011, 10:27:57 PM by ZG »
Offline tonedeaf
« Reply #2 on: October 02, 2011, 10:07:14 PM »
This is a Givi TB 11 that I attached to a Murph's rack. It works well, looks sanitary and should be able to attach your Givi trunk (I got the  rack with the Givi option). I also have a Sargents seat, which works better with the back rest than the stock.
Offline Armyguns
« Reply #3 on: October 03, 2011, 10:16:38 AM »
I have the same complaint from my wife.  On our 3000 mile trip to Nova Scotia we ended up rolling up a towel into a 'tube' and wedging that between the top of the rear portion of the seat and the bottom of the Givi. It worked but wasn't a long term solution.  I am also looking for a solution for when the Givi is installed.
2010 C14 ABS
Offline Loren
    • Baldwin Motorbike Saddles
« Reply #4 on: October 03, 2011, 11:20:33 AM »
My gal  had the same complaint about the Kawasaki 47L top case with the pad on it.  Before going the route of installing a backrest support bracket internal to the custom seat I made, I was going to make a lower lumbar support pad to install on the lower half of the case.  Same idea as Armyguns rolled towel.
Loren
www.MotorbikeSaddles.com
Offline AirplaneTim
« Reply #5 on: October 03, 2011, 05:03:54 PM »
Yeah, I'm thinking about moving the existing pad to the bottom of the case (flipping it upside down) and maybe making another pad out of foam wrapped in vinyl and attached to a baseplate that'll matches the bolt holes for the upper pad.
I am certainly a big fan of the corbin set-up, it looks really nice, but it's just not in the budget right now.
« Reply #6 on: October 03, 2011, 06:10:52 PM »
Take it off all together and see if that helps.  My wife prefers the E55 with NO pad.
