Author Topic: Which front stand do you recommend?  (Read 5060 times)
Offline ChuckW
« on: September 26, 2011, 10:25:42 PM »
I want to get the tires off the ground for the winter, so I'm planning to use the center stand and a front stand.  Which front stand works for you? Pit bull's chart doesn't list anything as compatible with the c14.
Alternatively, would a jack work better?
Offline OPUS
Re: Which front stand do you recommend?
« Reply #1 on: September 27, 2011, 07:25:33 AM »
I have not used it or could I recommend it yes or no but it looks like what you need. I have thought about one not sure I really need it.
http://cgi.ebay.com/ebaymotors/?cmd=ViewItem&_trksid=p3984.m1423.l2649&item=290476677313&sspagename=STRK%3AMEWAX%3AIT
Offline So Cal Joe
« Reply #2 on: September 27, 2011, 08:06:48 AM »
If you have it on the centerstand can't you use a bottle jack under the motor to raise the front wheel off the ground without having the rear wheel touch the ground?
Offline jonathan
« Reply #3 on: September 27, 2011, 08:39:47 AM »
Yes or you could put a pipe or rod through the front axle and support that on blocks or a screw or bottle jack.
« Reply #4 on: September 27, 2011, 08:51:09 AM »
Just curious as to why, do you keep your bike outside under a cover?
Offline BudCallaghan
« Reply #5 on: September 27, 2011, 09:42:19 AM »
Why do you want to elevate the front wheel?  When the bike is on the centerstand there isn't much weight on the front wheel.  The front tire can support that load for one hell of a long time and never know the difference.  The front wheel stand on the EBAY link recommended by OPUS appears to be a nice aftermarket creation at a reasonable price but to my way of thinking it's a bit like using an elephant gun to go squirrel hunting.
« Reply #6 on: September 27, 2011, 06:28:03 PM »
I take the back wheel off mine, then use this front stand in the pic to lift the front and remove the wheel. I would use a rear stand as well but why when sport touring bikes have a center stand?
PIT BULL brand race stands <---when second best stands are not an option for you.
« Reply #7 on: September 27, 2011, 08:28:47 PM »
+1... Pitbull stands are great!  :thumbs:
Offline bbhzx12
« Reply #8 on: September 27, 2011, 09:15:52 PM »
ZG:  If black ones are faster why did they arrive an entire year later than the silver?
« Reply #9 on: September 27, 2011, 10:02:35 PM »
They didn't know what they had in the first year and tried to be broad in their demographic...
Offline Barry
« Reply #10 on: September 28, 2011, 04:11:13 AM »
I agree - NOT a fan of a jack of any type under the motor or exhaust.  Much prefer to support the bike via a front stand and center stand.
Ordering me a Pit Bull.  If you have no experience with race stands, trust me on this and believe what the poster above says re: Pit Bull stands, if you do not want to drop the bike, buy a Pit Bull stand.  Period.  X2 if you are lifting a heavy C14 vice a featherweight supersport.
Barry
Offline MikeERideWNC
« Reply #11 on: September 28, 2011, 06:16:47 AM »
Yep... PitBull is the only acceptable option.
You should always check Craig's List for Pitbull stands. It is not like you can ever damage one. EVER! They are about indestructable.
You can get them cheap... I always buy when I find them for 75.00 or less.
Make the seller and offer, they might take 75.00.
Offline Mister Tee
« Reply #12 on: September 28, 2011, 08:14:09 AM »
On a C14, you're still stuck with using the center stand for the rear wheel.  I don't know how you could possibly adapt a rear race stand to work with a C14.  I use a jack under the headers to elevate the front wheel, and there is really very little pressure at all required to lift the front end at that point.
« Reply #13 on: September 28, 2011, 08:22:37 AM »
Race stand simply goes under the forks once the rear wheel is removed if I recall correctly I use the pit bull on so many bikes. I've used a jack a lot too on my C14 when my front stand was busy on other bikes.
Offline TimmyG
« Reply #14 on: September 28, 2011, 09:02:30 AM »
I used the center stand and a ratchet tiedown to lightly pull the back of the bike down lifting the front wheel
« Reply #15 on: September 28, 2011, 10:02:22 AM »
Just put one of these on the back...  ;)
« Reply #16 on: September 28, 2011, 01:47:38 PM »
That is very offensive she is a super nice lady with thyroid problems.
When they got married she was only 98 pounds.
Once she became manager of the Circle K the Little Debbie vendor gave her all of his out of dates.
Offline Barry
« Reply #17 on: September 28, 2011, 03:12:36 PM »
Soooo....  can we get a group buy for a Pit Bull front stand????
If we can, I am 100% in.
Smelling DISCOUNT !
As a reseller, could Murph get the business, make some $$$, get us a discount, and facilitate a large group buy?  Hmmm?  MURPH ?????
Barry
« Reply #18 on: September 28, 2011, 03:42:42 PM »
Offline ChuckW
« Reply #19 on: September 30, 2011, 07:36:42 AM »
Which stand and pins are you ordering for the front?  As I noted in the OP, pit bull doesn't mention the C14 in their fit charts.
