Author Topic: I want to tint my windscreen. What are the options?  (Read 14420 times)
Offline skeet
  • 2009 Concours 14
« on: September 24, 2011, 09:18:31 AM »
I have the stock shield and a ceebailys that I want to tint.
What have you guys done to accomplish this?
What type of paint and prep work?
I am not a painter but I could prolly swing this knowing some tricks up front.
I have seen people mention auto tint places but that it could curl up or bubble.
Thanks,
Wayne
Offline koval68
Re: I want to tint my windscreen. What are the options?
« Reply #1 on: September 24, 2011, 10:41:35 AM »
If I remember correctly, some of our forum members have used a VHT paint...
http://www.vhtpaint.com/products/niteshades/
- Mahatma Gandhi
Offline Barry
« Reply #2 on: September 24, 2011, 11:01:30 AM »
I did mine with a rattle can of satin black.  I've done 2, both turned out fine.  I paint the "back" side, or rider side, of the shield.
Top pic is of a OEM shield cut down 4", the others are the OEM shield just painted.  I needed a cut down shield for summer.
*EDIT*
I'm 5'9" ish and the OEM height painted shield is not a problem to see over.  FYI>
*EDIT*
Barry
And my Poodle likes it... so THERE.
« Last Edit: September 24, 2011, 12:15:25 PM by Barry »
Offline So Cal Joe
« Reply #3 on: September 24, 2011, 11:59:33 AM »
I have never tinted one but I would think you could take it to a window tint shop and they can do it. A rattle can would black it out and not just be a tint.
« Reply #4 on: September 25, 2011, 06:54:09 AM »
I wanted to tint my stocker and I used the VHT Niteshades stuff. I prepped the shield and did a test spray on another piece of plastic, seemed to work fine in my test so I gave the shield a go.
The valve on the can started to sputter and it messed up my nice even coat. I ended up using multi coats and blacking out the shield instead of tinting. I didn't like it and bought the CalSci tinted shorty instead.
I plan on cutting the blacked out shield down 3 or 4"and using it as my summer shield.
Offline Barry
« Reply #5 on: September 25, 2011, 07:02:25 AM »
FYI - the delta between full up, and full down, is 4".  I cut my OEM screen 4", so at full height, it is no higher than the OEM screen in the lowest position.  With it all the way down, I get really good torso/crotch airflow.  I'm 5'9".
Barry
Offline skeet
  • 2009 Concours 14
« Reply #6 on: September 25, 2011, 07:05:49 AM »
Thanks for the info. I was wondering if the rattle can went crazy what would happen. Sounds like once that stuff hits the screen you are committed to what ever you get. Blackening it out all the way would prolly be good with me. I always am able to look over the screen anyways.
What is the difference in appearance between full black out and the nite shades?
Seems like it would just be a darker tint? No other noticeable difference?
Thanks,
Wayne
« Reply #7 on: September 25, 2011, 07:09:25 AM »
Barry
4 inches it will be then.
« Reply #8 on: September 25, 2011, 07:11:36 AM »
I used VHT niteshades and the key to it is doing very light coats.  I got a little heavy handed and ended up with a black, cut down stocker.  It didn't bother me in the least since it is so short that I would have to put my chin bar on the tank when the shield is in the full up position to look through it.  But if you are careful you can get a tint effect from the VHT product, you just need to be more careful than I was.
« Reply #9 on: September 25, 2011, 07:15:08 AM »
Thanks,
Wayne
The Nite Shades if done right and on a small area yields good results and looks like a tint job. I tried to get it nice and even but when that valve sputtered it screwed up the whole thing. I had many a choice word to say about that valve when it happened; I got pissed and just put a bunch of coats on.
I'm certainly no painter so maybe someone else with some skills could get a nice even coat.
Offline skeet
  • 2009 Concours 14
« Reply #10 on: September 26, 2011, 03:02:54 PM »
Did you guys use any clear coat after?
Does the VHT Niteshades need the clearcoat?
Offline Barry
« Reply #11 on: September 26, 2011, 04:25:11 PM »
With my Krylon job, no clear.  I did the back side of the screen, so not needed.
Barry
Offline timbo
« Reply #12 on: September 26, 2011, 05:09:18 PM »
The blacked out screen looks awesome compared to the clear. Does anyone have a pic of the cal sci tinted shorty for comparison to the full blacked out?
Offline skeet
  • 2009 Concours 14
« Reply #13 on: September 27, 2011, 10:54:23 AM »
calsci tinted shorty.
Might be for sale if my tint job goes well on the stock shield.
« Reply #14 on: September 27, 2011, 11:01:34 AM »
Here's more pics of the shorty on a more beautiful and faster '08.
Offline Loren
    • Baldwin Motorbike Saddles
« Reply #15 on: September 27, 2011, 11:27:12 AM »
Conrad,  What are the small windscreens next to the mirrors?
Loren
www.MotorbikeSaddles.com
« Reply #16 on: September 27, 2011, 11:36:00 AM »
They are Motax hand wings.  You can see more in this thread.
http://www.zggtr.org/index.php?topic=306.msg3916#msg3916
You beat me to my edit, Loren.  I was a little slow on the draw.
Offline Loren
« Reply #17 on: September 27, 2011, 11:37:22 AM »
Found them...Motax
Loren
« Reply #18 on: September 27, 2011, 12:20:18 PM »
I love those Motax air deflectors! The pics above are from last year but I just put the air deflectors back on my bike as the temps are running a lil cooler lately. They move the air stream up above my hands and allow me to wear much thinner gloves than I would have without them and still have warm hands.
Offline Loren
« Reply #19 on: September 27, 2011, 09:22:52 PM »
Conrad, thanks....I contacted a Motax dealer in France to see about ordering a pair.
Loren
