Author Topic: Help - Throttlemiester install on 2011/2012 C14 with factory heated grips  (Read 2345 times)
Offline santeejd
New C14 needs my normal mods . Cee Bailey, throttlemiester, and risers.
          When trying to install my throttlemiester on my Connie I have some concerns. The throttle tube has another tube that holds the heating elements. TM says to cut tube, But afraid of damaging heater. tried fitting without friction and it works but not thrilled about it. Can get the friction tube about half way on between heater and throttle tube.
Thought about cutting friction ring by about half.
Curious how other guys with 2011's have installed them
on another note during break in did temp run a bar over half? never had tach  past the 4k. Seems hot to me. but only 50 miles so far
Thanks,
JD
1974 GT750 Lemans (water buffalo) 7K
 1998 Kannon V8 ZZ4
 2012 Concours 14 50 miles
Offline nyconcours
Re: Help - Throttlemiester install on 2011/2012 C14 with factory heated grips
« Reply #1 on: September 22, 2011, 10:02:29 AM »
I installed the throttlemiester on my 2010, had to remove two small spacers and leave the larger one. then used the friction on the grip and left the friction ring off.
Offline Mister Tee
« Reply #2 on: September 22, 2011, 10:15:22 AM »
You won't be happy if you leave the friction ring off.
1.  Lube the outside of the friction ring with a little wet bar soap.
2.  Pry the end of the grip with a screwdriver, work the friction ring under it, and push it in.  Use the Throttlemeister itself as a push in tool if you need.
Piece of cake.
Offline wnplt
« Reply #3 on: September 22, 2011, 11:52:49 AM »
Thats how I installed mine too.
Offline Khrome
« Reply #4 on: September 22, 2011, 04:37:33 PM »
 :o maybe this makes more sense if your looking at the parts... I dont have mine yet.
Khrome 2011 C14...09 Kaw Voyager...08 Yam WR250X...07 Yam FJR...06 Suz M109...04 Yam RoadStar...03 Kaw ZZR 1200... 02Kaw ZRX1200...01 KTM LC4...00 Kaw KLR 650...99 Kaw C10...98 Kaw ZRX 1100...94 Kaw Zephyr 750...85 Kaw 454LTD...79 Honda XL250S
Offline CADMAN97
  • 2010 C14 ABS
« Reply #5 on: September 22, 2011, 05:17:18 PM »
That's pretty much how I installed mine, and works great. Yes, using the friction ring would have been better, but using the factory grip still works pretty good IMO. Just used it today, and works as advertised.
Offline Necron99
    • Facebook Page
« Reply #6 on: September 22, 2011, 05:31:20 PM »
I rolled the rubber back and slid the ring on, no problem on my 2010.
-Dylan Thomas
2010 ZG1400 COG #9384
Offline santeejd
« Reply #7 on: September 22, 2011, 06:01:12 PM »
Done using the friction ring and the advise of the using the TM as the press! Thanks everyone for the input
 1998 Kannon V8 ZZ4
