Author Topic: ECU removal procedure  (Read 5973 times)
Offline NautiOne
« on: May 15, 2011, 07:32:26 PM »
I remember a good thread (with pics) about how to locate and remove the (correct) ECU. I'd like to send it in to Dynotronics for reflash and wish to do it quickly and easily.  Does anybody have that post to share?  TIA
"Now, bring me that horizon"
Re: ECU removal procedure
« Reply #1 on: May 15, 2011, 08:00:01 PM »
I can give you a verbal but photos will have to wait until tomorrow-
Remove the seat, then the toolbox (four screws, it is very easy). The ECU (the ECU that you want to reflash) is behind the toolbox, just under the shelf at the back of the saddle compartment. Remove one battery terminal before pulling the ECU to cut power before unplugging the ECU. The ECU will pull pretty easily toward the front of the bike and there will be two electrical connectors that plug into the bike's wiring harness. There is nothing other than a form- fitted rubber strap holding the ECU in place.
Offline Afm252
« Reply #2 on: May 15, 2011, 08:43:37 PM »
... I'd like to send it in to Dynotronics for reflash...
Make sure we get a solid write-up after the reflash. Don't need the butt dyno results, want the real story!
Mike T
09 C14 "Turtle"
07 CBR 600rr Blue/ Silver
98 CBR 600 F3 "Desert Storm"
« Reply #3 on: May 15, 2011, 09:01:24 PM »
Butt dynos are always optomistic....give us hard data!
« Reply #4 on: July 31, 2012, 03:13:27 PM »
There are two units, one with three plugins and one that has two plugins. I only need to send the one with two plugins correct?
« Reply #5 on: July 31, 2012, 03:24:27 PM »
You know, there are so many ways I could go with this but I've just had a beer and I'm in my mellow place at the moment.
« Reply #6 on: July 31, 2012, 03:40:54 PM »
 :o    :-X
« Reply #7 on: July 31, 2012, 03:43:11 PM »
http://www.pbase.com/fredharmon/accleads
« Reply #8 on: July 31, 2012, 04:03:34 PM »
Thanks Conrad, there are two units though. Do I ship both of them for the reflash?
« Reply #9 on: July 31, 2012, 04:16:48 PM »
Sorry, I don't know.
Check this out, http://www.pbase.com/fredharmon/image/135654388,
« Reply #10 on: July 31, 2012, 04:28:02 PM »
I saw that picture right after I posted :)
The correct one is what Brian said, the unit with two plugs.
