Author Topic: Calling all Tank Bag owners, looking for advice and photos.  (Read 38146 times)
I am researching Tank Bags and have the list narrowed down to a handful.  This was on the other site just before it went down.
I have updated the list with suggestions from the group:
Cortech Mini
Cortech Super Mini
Chase Harper 650
RKA SuperSport
Givi T480 with Quick Mount
First Gear Silverstone II
Nelson-Rigg Silver Streak SSC-110
Luggage Locker-Tank Locker
Rapid Transit Recon 19
Bags Connection Trial-Ql
I have found a lot of info on most all of these bags with the exception of the Givi T480 with the Easy Lock ring.  Has anyone used this system and what are your thoughts?  Others feel free to post any photos of your tank bags.  Maybe this can turn into a good reference thread for tank bags.
« Last Edit: May 16, 2011, 01:02:54 PM by 556ALPHA »
Bob
Re: Looking for advice on Tank Bags
« Reply #1 on: May 15, 2011, 07:44:50 PM »
The Chase Harper is a great bag. I tried a bunch on the C14 (at the dealer who had a great assortment). The Chase Harper fit the C14 the best and pretty much perfect. A good quality bag that I highly recommend for the C14!
« Reply #2 on: May 15, 2011, 08:10:28 PM »
My only concern with the Chase Harper is the map pocket.  It does not seem to be as stable or fixed as the others, any input on that?  tks
Offline JetJock
« Reply #3 on: May 15, 2011, 09:00:50 PM »
First Gear. I've got two: Silverstone for around town small stuff.
Laguna for trips, with a special GPS pocket that pops up.
Bob
« Reply #4 on: May 15, 2011, 09:07:23 PM »
It hooks on with four corner hooks, that are fairly hard to clip on/off. When installed, it isn't going anywhere. I leave it off unless I need it. I like the webbed, strapped top for holding or hooking things on quick. So unless I need to use the map pocket. It's normally in the side case with a map. Granted i use a GPS most of the time and a back up map.
Offline dbird29
« Reply #5 on: May 15, 2011, 10:22:06 PM »
Bought a Cortech Dryver that snaps on a gas cap ring.
http://www.motorcycle-superstore.com/1/4/71/36140/ITEM/Cortech-Dryver-Tank-Bag.aspx?WT.ac=SLIsearch
I like it so far.
2010 C14 Blue
2003 Buell XB9S
1982 GPz 750
« Reply #6 on: May 15, 2011, 10:25:50 PM »
I use a Cortech mini magnetic and I love it. It doesn't move a bit and comes off instantly for refueling and I also like the map case. The map is right there for reference and stays dry.
Offline Irish-14
« Reply #7 on: May 16, 2011, 04:23:57 AM »
Why use a small tank bag, when bigger bags don't get in the way? Unless it's the perfect day and you need very little, I can always think of things to put into my tank bag. I got a 19 litre bag (Motocentric Mototrek 19)and never looked back. It doesn't get in the way, it looks good, and if I need the room I have it. Happy riding gentlemen and Go Irish!
Bob
« Reply #8 on: May 16, 2011, 06:10:04 AM »
Because I find all tank bags are in the way to some extent. The bigger they are, the worse it is (for me). So I use different size tank bags. I use the smallest tank bags I can normally get away with. A smaller bag close to home. A larger bag when traveling. Although I did buy a very slightly used Bagsconnection tank bag with the SWmoto ring for my FJR. If I like it, I will have to resort to using just one bag!
Offline JetJock
« Reply #9 on: May 16, 2011, 06:27:25 AM »
Ditto. I don't want a big tank bag to deal with for just around town stuff.
Offline JoeR
  • COG 9284 / AMA 668669
« Reply #10 on: May 16, 2011, 08:10:10 AM »
Offline DaveO
« Reply #11 on: May 16, 2011, 10:18:05 AM »
i love tank bags Magnetic tank bags specificly.
I havent found one that will work on my 09 c14 with glove box in the way.
Sure you can get one on there  but not the place i want it to be located.
Ive given up on tankbags for this bike ..Pretty happy with my soft tailbag I suppose.
Offline JoeR
« Reply #12 on: May 16, 2011, 10:35:54 AM »
I use the Rapid Transit Recon 19 on my '08 with the center glovebox, no problems there.  It does have to be moved to gas up.
Offline DaveO
« Reply #13 on: May 16, 2011, 10:48:14 AM »
do you cover the glove box with the bag ? Post a pic if possible
« Reply #14 on: May 16, 2011, 10:50:16 AM »
Hey Cap'n Crunch, what is the material on the bottom of the CH650?
Is it soft and cuddly like a microfiber blanky or is it gritty like the side of your luggage?
Offline varnado
« Reply #15 on: May 16, 2011, 11:12:18 AM »
The magnetic or strap connected?
Ride Safe, Randy
08' Concours 14
08' B-King
Offline koval68
« Reply #16 on: May 16, 2011, 11:50:07 AM »
I am very pleased with Bags Connection Trial-Ql.
http://www.twistedthrottle.com/trade/productview/2624/451/
- Mahatma Gandhi
Offline Tactical_Mik
  • Lamh laidir an Uachtar
Re: Calling all Tank Bag owners, looking for advice and photos.
« Reply #17 on: May 16, 2011, 01:47:47 PM »
I use the trial ql when going on longer trips and the recon 19 for shorter trips but am also looking for a smaller one for around home way.
T.S.R.
Bob
« Reply #18 on: May 16, 2011, 02:21:43 PM »
Its textured but soft.
Bob
« Reply #19 on: May 16, 2011, 02:23:09 PM »
I just got one of these to try on the FJR. The thing is so big I have to move my GPS!
