Author Topic: Problem with Sargent seat  (Read 2344 times)
Offline Gsun
« on: September 17, 2011, 07:04:37 PM »
I just bought a Sargent with pod and it is really hard to get it on the bike. Is there a trick I am missing or is that just the way they are?
Offline accbiker
Re: Problem with Sargent seat
« Reply #1 on: September 17, 2011, 07:10:06 PM »
I know that with the low version I have to slightly arch the seat to get it to lock properly.  It is as if it is about a 1/4 inch too long.  But pulling up in the middle of the seat slightly seems to work each time.
-David
Athens, GA
Offline Gsun
« Reply #2 on: September 17, 2011, 07:15:58 PM »
-David
Athens, GA
That is what I did. Arch the seat, push down on the rear to lock it in and then push down in the middle to get the hooks to engage.
Offline GaryW
  • 2011 C14 Black
« Reply #3 on: September 18, 2011, 06:00:45 AM »
I just bent the rear bracket ever so slightly forward, problem was solved.
« Reply #4 on: September 18, 2011, 07:16:27 AM »
That is just the way they are.  I have the same exact problem and even commented to them about it.  Otherwise, I really like the thing.  Thankfully, I very rarely have to remove the seat.
Seems I have to "bend" the seat a bit when putting it on.  I also tried to bend the locking bracket a tad, which helped some... can't remember exactly what I did.
Offline So Cal Joe
« Reply #5 on: September 18, 2011, 07:46:58 AM »
I bent the rear bar that locks into the bike, but still had to push the rear of the seat forward when mounting it on the bike.
