Author Topic: Part Number For Push Rivet Under Windshield 2011  (Read 6180 times)
Offline Zman
« on: May 15, 2011, 05:35:40 PM »
What is the part number of Push Rivet under the 2010-11 windshield...... Is there a after market equivalent that can be purchased locally?
Offline Tactical_Mik
  • Lamh laidir an Uachtar
Re: Part Number For Push Rivet Under Windshield 2011
« Reply #1 on: May 15, 2011, 05:53:05 PM »
This was taken from the old forum.  Not sure of the informations validity for your case.
Nylon Push Rivet (two sizes) - 92039-0051 & 99039-0051
Push rivet under the windscreen - 92039-0048
Motosport.com Bolt Brand 6mm Nylon Push Rivet - 2005-6RIV (These may not work)
Balkamp part number 665-1446 (pkg of 9) available at NAPA for (rivet 92039-0051)
Hillman push-in Nylon Rivet - 1/4 inch H#881216 (Lowes) barcode 0823671607, for the top of dash
T.S.R.
« Reply #2 on: May 15, 2011, 06:07:20 PM »
The local ones are usually slightly different and have a straight pin body- that type won't work very well when it is time to remove them. I have found the factory type rivets at two places, one is Grainger: http://www.grainger.com/Grainger/Push-In-Rivet-5MUF8
And the other is Amazon: http://www.amazon.com/Tusk-Kawasaki-Suzuki-Fender-Rivets/dp/B0039LEU0I
I have not used or purchased either one though so they may not be exact matches. The ones from Amazon are pretty reasonable in price ($5) but cost more to ship ($7). The ones from Grainger are come in a bigger package (25 vs 10) but may be cheaper because you should not have to pay shipping.
Bob
« Reply #3 on: May 15, 2011, 06:15:22 PM »
<snip>
These are the part numbers that Ron Ayers lists!
