Author Topic: 2012 black grab rails installed!  (Read 20051 times)
« on: September 12, 2011, 03:40:37 PM »
Anyone have the parts fish for these to check the part number??
The new 2012 has black grab rails, I'm thinking maybe just get the 2012 ones (which "should" be the same as the 10/11's) rather than paint my 09 ones, that way I don't have to worry about the paint finish etc...
Are the 2012 parts fish available yet?? If so, can somebody share the 2012 part number for these??
Thanks!  :grouphug:
« Last Edit: September 21, 2011, 08:20:18 PM by ZG »
Re: are 08/09 passenger grab rails the exact same as the 10/11 ones?
« Reply #1 on: September 12, 2011, 04:00:32 PM »
Thanks!  :grouphug:
As the bike hasn't been announced officially I rather doubt they're available yet.  They're still hawking the 2011 on the US and UK Kwak sites.
Offline Beamer
« Reply #2 on: September 13, 2011, 02:03:07 PM »
Thanks!  :grouphug:
Not to sound smart, but have you considered powder-coating them? Probably can get them done pretty reasonably. I had some snowmobile front suspension stuff done a few years ago (Front A-Arms and Spindles) and I don't think I had $50 into 6 decent sized components.
« Reply #3 on: September 13, 2011, 02:09:52 PM »
Can't, they're plastic...  :(
« Reply #4 on: September 13, 2011, 02:22:41 PM »
Yep, that is correct, at least on the '08's and I can't imagine they changed the material on other years. I drilled a couple of holes in mine "knowing" they were aluminum- imagine my surprise at the resin chips coming off of the drill bit.
« Reply #5 on: September 14, 2011, 07:06:35 PM »
I just ordered the black 2012 rails, they're available and "my" cost was about what my painter wanted to redo mine...
 :banghead: :loco: :nuts:
I need a farkle intervention...
« Reply #6 on: September 15, 2011, 01:18:16 AM »
how? where from? how much? ME WANTS IT.
« Last Edit: September 15, 2011, 02:01:54 AM by martin_14 »
« Reply #7 on: September 15, 2011, 09:53:09 AM »
I just ordered them through my local shop, they looked them up and it said they were available. I get a discount from being such a parts ordering slut so my cost was $160 for the pair, I think retail is probably about $200...
Do you think I'm maybe the first to order 2012 C14 Kawi parts? I can't imagine somebody has already bought and wrecked a 2012 and is having to order replacement parts??  ???
I just hope they fit...  :-\
Offline Kiwi Graham
  • Country: nz
« Reply #8 on: September 15, 2011, 01:12:36 PM »
Na, a couple of we slides but nothing to write home about  ;)
« Reply #9 on: September 16, 2011, 04:38:41 AM »
please do let us know how it turns out...
« Reply #10 on: September 16, 2011, 08:07:15 AM »
Will do Martin...
Offline Tremainiac
« Reply #11 on: September 16, 2011, 12:01:53 PM »
ZG
Your painter wants $160-200 to paint the 2 hand rails??   :yikes:
That'll buy a heck of a lot of rattle cans!!
Hey mister, my sister has a Harley 'just' like yours!!
2009 Concours 14, 2003 Triumph Thunderbird Sport
1980 Honda CM400 street tracker, Grubee Skyhawk
« Reply #12 on: September 16, 2011, 10:06:41 PM »
ZG
I'm not looking to "rattle can" anything on this bike at this point, I'm sure I'd make it look bad somehow...
Maybe I should just wrap the grab rails in black duct tape...  ;)
« Reply #13 on: September 17, 2011, 10:17:43 AM »
Yea thats a univerasl solution, and paired with the mighty KiPass it'll last forever
How do you remove the rear passenger grab rails?? Full tail removal required??
« Reply #14 on: September 21, 2011, 03:21:16 PM »
Ok, my 2012 black grab rails arrived today!  8)
Question though, I pulled the rear seat (my Smuggler actually) off and it looks like I can't get to all the mounting bolts that hold the rails in??
Do I really need to remove the whole freakin tail to swap these out??  :-\   >:(
Please help a brutha out here...  :grouphug:
« Last Edit: September 21, 2011, 05:02:39 PM by ZG »
Re: How do you remove the rear passenger grab rails?? Full tail removal required
« Reply #15 on: September 21, 2011, 05:10:07 PM »
I am not sure but I think so- they are pretty intertwined with the rest of the bike and mount in several places. The Givi 55 C-14 mount 'arms' reach under the rear fender and attach to the bottoms of those rails so they go pretty deep in the bike.
You should be able to tell how involved it is going to be by holding a new rail up to the bike.
Pull the rear side plastic and that one little plastic piece under the front of the rear rack and you should have it.  However I'm
not removing my rails to prove it. I could be wrong if any of those bolts are going into nuts instead of threaded frame holes, in which case more may need to come off to access the nuts and keep 'em from spinning. But I think you'll be OK.
The Givi mount 'arms' are going to the steel sub frame not the plastic. (Brian I know ZedHed put you up to this, now cut that out.   ;D  ;) )
Progress, on a roll now, half way point...  :)
« Last Edit: September 21, 2011, 09:31:10 PM by ZG »
« Reply #18 on: September 21, 2011, 07:24:55 PM »
I believe you are correct but on the other side of that bracket are the bottoms of the lifting rails. Seriously. I read the instructions for the Givi 55 C-14 mount and that is where the mounting arms bolt and also the end (bottom) of the rails.
<snip>
« Reply #19 on: September 21, 2011, 07:26:00 PM »
Ah, just like doing a valve lash check: half- way done, 90% left to go.... There is nothing there that alcohol won't fix or at least make you forget later.
Proress, on a roll now, half way point...  :)
<snip photos>
