Author Topic: all cams that fit ?  (Read 2987 times)
Offline mach1charlie
  • Lone Wolf... No Club
all cams that fit ?
« on: September 03, 2011, 10:54:11 AM »
Could someone post a run down of all Kawie cams that fit in the c10 ?
TIA Charlie
Real men have tire irons, and use them.
Charlie
Offline GeeBeav
Re: all cams that fit ?
« Reply #1 on: September 03, 2011, 12:43:25 PM »
85-86 ZL900 and 87 ZL1000 are same as Conc.
84-86 ZX900 and 86-87 ZX1000 fit, but are higher lift, top-end oriented.
Offline Steve in Sunny Fla
    • Shoodaben Engineering
« Reply #2 on: September 03, 2011, 12:55:03 PM »
and then there are these - and I also have the high - lift version in limited availability - Steve
 http://sites.google.com/site/shoodabenengineering/replacement-torque-cams
Offline syntor
« Reply #3 on: September 03, 2011, 05:34:14 PM »
GPZ750 fit, but I don't know about lift/duration etc.
Offline connie_rider
« Reply #4 on: September 04, 2011, 09:08:32 AM »
Charlie, what are you up to?
Are you having Cam problems?
« Reply #5 on: September 04, 2011, 11:00:34 AM »
Yep, I am on a road trip, 200 miles from the house it started ticking, I thought ex. leak. 400 miles down the road it was louder. stoped in NC. and ran the valves, bad intake cam. F**k it, got about 2600 ticking miles on it now, and will ride it home!
Any one between Maine and Florida got a cheap cam and rockers ? I will pick it up !
FYI bike has 32k
Charlie
« Reply #6 on: September 04, 2011, 02:34:28 PM »
I just fixed one like that 2 weeks ago, a rocker had failed and had a 1/2 moon worn into it. Bike was noisy, but still ran... Good luck on the trip - steve
« Reply #7 on: September 04, 2011, 06:28:38 PM »
Charlie, my first thought is, when you get back to Florida, get with Steve and install a set of his Torque cams.
(Or his Power cam if he still has a set)
Or, get back to us here. Someone will have cams.
Whatever you do, let us know you made it home safely!!!
« Reply #8 on: September 07, 2011, 12:02:29 PM »
Woohoo, Bought a coplete 900 head for 40 bucks, will pick up in TN.
Can't complain about used part prices for these bikes !
Charlie
Offline este.el.paz
« Reply #9 on: September 08, 2011, 02:35:32 PM »
Gents:
I'm new to this list, been spending most of my Konk time on COG at micapeak.  I've had my 86 for about 20 years so I've been through most of the C-10 issues once or twice.  I don't know the players here, but just stumbled into this post while looking for ways to upgrade the C-10.
But, has anyone mentioned "cam chain tensioner" to address mach1's valve ticking?  32K could put it right in the mix as far as the C-10 goes.  It seems a little early for bad cams and apparently the C-10 cams can look really bad and it doesn't reflect in terms of performance or sound.  Whereas the old "ticking valves" issue can be solved by pushing up a tired cam chain tensioner while the engine is COLD or getting a new one . . . to take the slack out of the cam chain.  It's the idea of the easy way or the hard way, or the way that addresses the issue way . . . ?????
e.e.p.
86 Konk 100+K SoCal
« Reply #10 on: September 08, 2011, 03:25:06 PM »
Thanks for you response eep. I will check the chain adj.
Charlie
« Reply #11 on: September 09, 2011, 05:15:46 PM »
If you like power below 5000 rpm, you're not gonna like those cams. I messed with them for years, and the connie will be slower in everyday accelleration with the zx cams. lot'sa fun over 7000 though! Steve
« Reply #12 on: September 14, 2011, 04:13:40 PM »
e.e.p. are you a member of the club?
Don't see a name and don't recognize your sig.
If your not and have had a Connie for 20 years,,, come ride with us!
You'll like this crowd!!
