Author Topic: Lowering the shifter  (Read 3846 times)
Offline So Cal Joe
« on: August 25, 2011, 07:24:00 AM »
My 09  has stock pegs but I find that I have to raise my boot kind of high to shift gears, can the shifter be moved down some and how do I go about doing it?
Offline COGnosticat0r
Re: Lowering the shifter
« Reply #1 on: August 25, 2011, 08:14:37 AM »
On the shift bar there are two nuts, one is reversed thread.  Take two 10mm open end wrenches and loosen both nuts.  Take the middle bar and spin it, not sure if clockwise or CCW but turning that bar will move the shifter up or down. Get it to where you want it, then tighten the nuts back and go ride   ;)
Jerry Holland
COG 4478
2013 C14
Offline stlheadake
  • Probably not my smartest day...
« Reply #2 on: August 25, 2011, 05:56:11 PM »
DANG Jerry!  That was about as succinct and simple as it gets!  Having done this a few times I was processing the procedure, and thinking about the instructions.  It's not a difficult job by any stretch, but you described it perfectly!
What do you call those three wheeled Goldwings?....Chicken Wings
08 C14 WOW what a bike!
00 XR650r Hare Scrambler
Offline So Cal Joe
« Reply #3 on: August 25, 2011, 07:46:39 PM »
Thank you, I'll do it before my next ride.
Offline Y0ssarian
« Reply #4 on: August 26, 2011, 07:09:36 AM »
Like this:
Offline So Cal Joe
« Reply #5 on: August 26, 2011, 12:08:17 PM »
Thank You
« Reply #6 on: August 26, 2011, 02:00:37 PM »
I did it the day I got my bike. It was way up there! :o
Offline So Cal Joe
« Reply #7 on: August 26, 2011, 02:20:42 PM »
Done, that was easy, Thanks again for the help
Offline KawiMick
« Reply #8 on: August 27, 2011, 02:53:20 PM »
Joe,
  The shifter is easy compared to the brake pedal.  I had to lower my brake pedal enough to
match my other bikes.  Had to remove the rear master cylinder. :(
Mick
'84 R100RS Pearl White Last Edition
'93 K1100LT Astral Blue Metallic
'96 R1100RT Sine Blue  Tucson,AZ/Santa Paula,CA
'10 C14 Candy Neptune Blue         Born OK the First Time
« Reply #9 on: August 27, 2011, 03:58:52 PM »
It shifting quality affected?
« Reply #10 on: August 27, 2011, 08:11:50 PM »
No, not if the only thing adjusted is the turnbuckle, which is what the above posters are talking about. There is an additional way to adjust the shifter lever placement and that is by rotating the clamp around on the shifter input shaft, just like in the olden days when that was the only way to adjust the lever. If you happen to run out of turnbuckle adjustment you can always jump one or two teeth on the input shaft but the shifter works best if the input to the shifter shaft is as close to 90 degrees as possible.
