Plans for and results for the "Bearing Up Shifter" C14
My C14 has no need for improved shifting linkage .. bike shifts fine as Kawasaki OEM intended it .. (Will not buy the Bearing Kit)
15 (22.4%)
My C14 may benefit from improved shifting linkage and I will / may buy the Bearing Kit / Or my Own Design
14 (20.9%)
I have already installed the Bearing Up Kit / or My Own Design and found slight to no shifting improvement
13 (19.4%)
I have already installed the Bearing Up Kit / or My Own Design and found significant shifting improvement
17 (25.4%)
After lubing the OEM shifter bushing / linkage points shifting is improved (no need for bearing kit)
1 (1.5%)
I lubed the linkage points regardless of the need or lack of need for the bearing up shifter kit
2 (3%)
I did the bearing upgrade myself / did not use Murph's kit
5 (7.5%)
Total Members Voted: 62
Voting closed: August 29, 2011, 07:08:45 AM
Author Topic: Bearing Up Shifter (Poll)  (Read 8981 times)
Offline JRO
Re: Bearing Up Shifter (Poll)
« Reply #20 on: August 24, 2011, 09:04:52 PM »
I was happy until I was told I was not... Stock, as is, no mod, no special attention, never really looked at it... How forked is my shifter after 20k?
admin edit: profanity.
« Last Edit: August 25, 2011, 05:11:07 PM by Rick Hall »
Offline mkorn
« Reply #21 on: August 25, 2011, 09:34:32 AM »
I did get and installed the bearing shifter kit.  But at 3,000 miles i doubt there was any need to.
but now it should shift the same for the duration of my time with the bike.
2009 C14 ABS
2002 750 Nighthawk (sold)
2006 DRz 400s
