Author Topic: Tire changer  (Read 5536 times)
Offline Tabarswaacky
Tire changer
« on: May 14, 2011, 01:40:42 PM »
I have a Harbour Freight  tire changer on order.
It apears that the motorcycle attachement is no longer available.
Does anybody know what the diameter of the axle bolts are. Concours 14?
Apparently the beadbreakers limit is 16.5 inches.
Has anybody extended it to 17 inches ?[/b
]I'm not ready to take the wheel off yet, otherwise I would measure it myself.
Thank you
Re: Tire changer
« Reply #1 on: May 14, 2011, 01:47:14 PM »
this really needs to be in bike accessories thread area....
the bead breaker dimension is from the center outwards, so that means it has a 33" dia rim capacity......more than enough for the tires on a C14.
axle is 17mm dia.
Re: Tire changer
« Reply #2 on: May 14, 2011, 04:59:09 PM »
There is no effective limit on the size of a motorcycle tire (diameter) that the bead breaker can handle. I believe the limit you are refering to is the width of the tire and wheel, not the diameter of the wheel. You will not have any problem breaking the beads on any motorcycle tires with that bead breaker.
Unless of course you really do have a 17" wide rear tire.  ;)
Thank you
Offline manowarwi
    • Midwest Sport Riders
Re: Tire changer
« Reply #3 on: May 14, 2011, 05:11:39 PM »
I've changed 17" tires on a harbor freight setup with no problems.  My only advice is let your new tires sit in the sun for a while before you put them on.  I had the pleasure of putting cold tires on my R1 and I fought with it for quite a while.
Offline Steve D
Re: Tire changer
« Reply #4 on: May 14, 2011, 08:06:32 PM »
Thank you
I don’t think the harbor freight tire change stand is going to do you any good without the motorcycle wheel attachment.  You will not have a way to mount the wheel.   I bought mine a few weeks ago and got the last combo set up in my local store.
Offline manowarwi
Re: Tire changer
« Reply #5 on: May 14, 2011, 08:17:07 PM »
Just a suggestion to everyone who has or is looking at the Harbor Freight tire changer, you should look into getting these blocks:
http://home.comcast.net/~prestondrake/mojoblocks.htm
They will help keep your rim from getting banged up.  My co-worker who has the harbor freight changer swears by them.  They also sell a mojo lever that also makes the process easier.
Offline Lonerider
Re: Tire changer
« Reply #6 on: May 15, 2011, 05:35:37 AM »
And I also have the Mojo Lever which works just as advertised and makes this a very simple job. Also don't forget to use some Ruglyde.
2009 ZG1400 Concours, 2003 SV1000, 1985 XV1000 Virago
Offline gonzosc1
Re: Tire changer
« Reply #7 on: May 15, 2011, 06:44:01 AM »
where could someone get a motorcycle wheel attachment?
Offline Steve D
Re: Tire changer
« Reply #8 on: May 15, 2011, 09:47:53 AM »
Harbor Freight discontinued theirs a couple of months ago.  I was told that the only possibility was to check at local stores in your area to see if they had any left.  I got lucky and found one.
Offline crashdb
  • 2010 C14
Re: Tire changer
« Reply #9 on: May 18, 2011, 12:34:13 PM »
I don't know what the price difference is off my head, but there's a changer out there called No-Mar.  This thing is basically a person-powered motorcycle tire changer that works similar to the air-powered one.  I believe it's a little expensive, but from what I've seen it's well worth the cost.  Do a search.
I feel like a new person!
Bob
Re: Tire changer
« Reply #10 on: May 18, 2011, 02:50:24 PM »
I use a Harbor Freight tire machine with a Nomar bar. A great combination. It has no breaking the beads or holding the wheel to change the tires for the C14!
Thank you
Offline ccrider
Re: Tire changer
« Reply #11 on: May 18, 2011, 03:48:08 PM »
You most likely don't need the motorcycle attachment. If you can fix a rod through the center of the changer that the wheel can slide over, you can change the tire. The only thing the M/C attachment does is provide a central pivot point around which you lever the tire iron.
Offline cablebandit
Re: Tire changer
« Reply #12 on: May 19, 2011, 06:51:42 AM »
It kind of holds the rim as well.  ;D
Offline Steve D
Re: Tire changer
« Reply #13 on: May 19, 2011, 11:13:19 AM »
Maybe you are thinking the attachment is the “C” shaped piece that holds the top of the rod that goes into the axel hole.  That is part of it but you don’t need that part what you do need is the 3 spoke piece that sits on top of the basic stand and actually clamps on to and holds the wheel.  That does not come with the basic changer.
Offline JetJock
Re: Tire changer
« Reply #14 on: May 20, 2011, 04:39:48 AM »
Taberwacky, why do you type with SUCH BIG LETTERS? Hard on the eyes.
