Author Topic: C14 - TPS 90 degree Valve Stem?  (Read 14736 times)
Offline IRULE
  • How sweet it is...
« on: July 28, 2011, 10:31:37 PM »
Do I really have to pay $50 for having a 90 degree valve stem??  See link.
http://www.murphskits.com/catalog/product_info.php?products_id=417
Or can I just buy the cheap-o 90 degree valve stem like this (I know this one is for older Concours, but can I still use it on C14)??  See link.
http://www.murphskits.com/catalog/product_info.php?products_id=43
I hate to $50 for 'little' more convenience...
2009 Red Buell 1125CR
1978 Triumph Bonneville
Offline C1xRider
Re: C14 - TPS 90 degree Valve Stem?
« Reply #1 on: July 29, 2011, 12:18:32 AM »
Not if you want to keep your TPM sensors.  The C14 style acts as a nut for the threaded sleeve / tube that holds the sensor in place.
Offline gonzosc1
« Reply #2 on: July 29, 2011, 01:45:51 PM »
I'm a cheap ass so I went a different route. found some $10 screw on 90 degree valve stems. I just keep them in the tire fix kit and just screw one on when I need air then unscrew it and done,,,,did I mention $10 on ebay
« Reply #3 on: July 29, 2011, 02:06:33 PM »
I got mine at a BMW shop for about the same price...
Offline IRULE
« Reply #4 on: July 30, 2011, 09:40:14 AM »
Do you mine take a picture of your screw on 90 degree valve stems for me? I seems to not able to find it. Thanks
Offline gonzosc1
« Reply #5 on: July 30, 2011, 12:17:17 PM »
can do it monday, not at home for the weekend and don't have cam with me.
i'll look around on the web and post link if I can find them..
Offline IRULE
« Reply #8 on: July 30, 2011, 05:40:30 PM »
Perfect. Much thanks.
Offline Burbs
  • 2009 ABS
« Reply #9 on: July 31, 2011, 06:03:33 PM »
So this means there's no possible way that a 90 degree valve stem would work with the TPS right?
-Chris
Offline C1xRider
« Reply #10 on: July 31, 2011, 08:07:40 PM »
-Chris
No, it means if you want to replace the valve stem with a standard non-TPMS valve stem, you don't get to keep the TPMS.  The one that Murph sells replaces the upper half of the valve stem assembly with a 90 degree part.
The ones shown in the eBay link simply replace your existing valve cap, and thread onto the stock valve stem.  Other than their height and additional weight (may require wheel re-balancing), they should work just fine.
When I installed the Murph style, I had to add several ounces of weight to the opposite side of the wheel.  It could have been the new tire I installed at the same time, but I don't think so.
Offline IRULE
« Reply #11 on: July 31, 2011, 09:31:54 PM »
$50 bucks for the tpms type for replacement seems a lot. I will go with the cheaper the version.
Offline Murph
« Reply #12 on: July 31, 2011, 09:38:57 PM »
The units we sale are designed and made for the LDL TPS sensor.. as a matter of fact they are LDL units 8)
LDL is based in France which explains a little about the price, but, the bottom line is, these are the only units on the market designed to work with that $160 sensor in your wheel ( that I'm aware of) if not, hey they are OEM stuff for said sensor.  If you want to twist one of those $10 units on to get air in your tire and then take it off, thats great. HOWEVER, I wouldn't recommend leaveing it on the tire. They put a surprising load on the valve stem when your humming down the road
Murph
COG 2769
Industry Member
Offline gonzosc1
« Reply #13 on: August 01, 2011, 02:29:20 PM »
Murph
COG 2769
Industry Member
+1 on the cheapies,  screw them on and add air. then take them off for riding!!
« Reply #14 on: August 01, 2011, 04:04:20 PM »
+2
Offline IRULE
« Reply #15 on: August 01, 2011, 10:51:50 PM »
Offline alansides
  • Spring has sprung
« Reply #16 on: October 09, 2016, 07:18:04 AM »
Just bought two 45% extensions on Amazon for $8.
https://www.amazon.com/gp/product/B017CW5RX8/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
If you want to wait a couple weeks and buy just one, they are as cheap as $2.57.
« Reply #17 on: October 12, 2016, 04:43:15 PM »
Those are freaky looking.  Wouldn't 90 degree work better than 45?  Also, I think they are not 45 degree but 135 degrees! (They are MORE than 90 degrees, not less)  Do you plan on leaving those connected all the time?  (Looks like they might could lead to leaking.)
« Reply #18 on: October 12, 2016, 05:53:22 PM »
Tell us how those work out for you...
My opinion is they look to put the end in an even more wonky position for fill and check, now, couple that with a second valve in the stem that can fail, and also another connection point when its screwed on, and it looks silly to me.
Silly, and prone to failure....
But then I have no issue filling my tires... with the oem units in place, go figure....
Offline kzz1king
« Reply #19 on: October 12, 2016, 08:27:26 PM »
[/color]
Me either, a fix for a problem that doesnt exist!
2010 CONCOURS
1974 Z-1
