Author Topic: ECU reflash  (Read 7821 times)
Offline bob14
  • go forth and meet the shadowy future without fear
ECU reflash
« on: May 11, 2011, 04:37:09 PM »
Don't remember but ....
Who has done this on a 2008 with Area P pipe only.
I'm looking for MPG maybe a little torque change
2008 C14
COG 8211
AMA 848986
Some people try to turn back their odometers. Not me, I want people to know "why" I look this way. I've traveled a long way and some of the roads weren't paved.
Re: ECU reflash
« Reply #1 on: May 11, 2011, 04:53:43 PM »
There was a lot of info here I wish we get back.
Re: ECU reflash
« Reply #2 on: May 11, 2011, 05:26:11 PM »
You got that right...
Offline Dan_from_WA
Re: ECU reflash
« Reply #3 on: May 11, 2011, 09:04:05 PM »
Hi all.  Relatively new to this forum, just purchased a new 2010 ABS this past January & was following the ECU reflash threads closely, then the forum crashed.  Like you, hoping some of that good info can be retrieved!
Dan
2010 C14 ABS, 1999 Blackbird, 1986 C10, 1981 GS1100E
AMA #395399
Offline blue14
Re: ECU reflash
« Reply #4 on: May 11, 2011, 09:29:54 PM »
Guhl Motorsports and Dynotronics were the two companies that were seling the reflash.
2010 C14, 2007 ZX14,  2004 KTM 300SXC
Re: ECU reflash
« Reply #5 on: May 11, 2011, 10:45:55 PM »
And I was really interested in their posts here.  Especially for my 08.
Re: ECU reflash
« Reply #6 on: May 11, 2011, 11:01:58 PM »
Yup, still would like to see some before and after dyno runs on either one.
Offline blue14
Re: ECU reflash
« Reply #7 on: May 12, 2011, 05:24:25 AM »
I recall someone posting about having their reflash for a 200RPM sooner opening on the flies.  That doesn't seem worth it.
Offline bob14
Re: ECU reflash
« Reply #8 on: May 12, 2011, 05:36:43 AM »
For me it might...
The bike comes "pig rich" the reflash cleans all that up. It is supposed to smooth ( the already smooth) throttle response
and torque curve .Sounds like a winner for 2 up . :chugbeer:
The 200RPM earlier was what Joe has in the reflash map he will adjust that to your likes
« Last Edit: May 12, 2011, 05:39:18 AM by bob14 »
2008 C14
COG 8211
AMA 848986
Offline bob14
Re: ECU reflash
« Reply #9 on: May 12, 2011, 05:41:30 AM »
From correspondence I had with Joe :
We can sure open the plates sooner, no problems.
We do do most of the BMW and other Euro bikes, including all the 2010 ducati's, BMW's, and Aprilias
http://www.dptune.com/  web
dyno@dptune.com  email
« Last Edit: May 12, 2011, 05:44:36 AM by bob14 »
2008 C14
COG 8211
AMA 848986
Offline blue14
Re: ECU reflash
« Reply #10 on: May 12, 2011, 06:39:11 AM »
How much sooner?
Offline bob14
Re: ECU reflash
« Reply #11 on: May 12, 2011, 07:14:39 AM »
it took him a day but shoot him an email. I got good answers to all my questions.
Sounds like a good guy.
2008 C14
COG 8211
AMA 848986
Offline Afm252
Re: ECU reflash
« Reply #12 on: May 12, 2011, 09:04:46 AM »
Gents,
Joe is just down the road in New Braunfels. He stated that the ECU would be turned around in 24hrs. Bottom line: He will map it however you want it to be mapped "customer is always right", however he has the optimized map that he has built through his Dyno. Unknown what modifications were on the bike he used.
$400 bones to get it done for the '08/ '09s. I look to get it done after I replace the more important tires.
Mike T
09 C14 "Turtle"
07 CBR 600rr Blue/ Silver
98 CBR 600 F3 "Desert Storm"
Re: ECU reflash
« Reply #13 on: May 12, 2011, 01:57:58 PM »
Some of the info from the old site is still available. Follow this link.
Look for the cached link at the end of the URL. It's a pain but what you're looking for might be there.
http://www.google.com/webhp?hl=en#sclient=psy&hl=en&site=webhp&source=hp&q=site:concours.org+reflash&aq=f&aqi=&aql=&oq=&pbx=1&bav=on.2,or.r_gc.r_pw.&fp=46498479c777e7ce
Offline Kazairl
Re: ECU reflash
« Reply #14 on: May 12, 2011, 02:03:39 PM »
I might have missed this in the old thread, Does the ECU have separate maps for each gear like the PCV?
Offline Afm252
Re: ECU reflash
« Reply #15 on: May 12, 2011, 02:46:25 PM »
Seperate maps only on the '10 and above from what I understand.
Mike T
09 C14 "Turtle"
Offline dynotronics1
Re: ECU reflash
« Reply #16 on: May 12, 2011, 06:53:10 PM »
yes they do! 1-2, 3-4 and 5-6 are all different timing curves. The lower two sets are far to mild for the way this bike should run
Offline Zman
Re: ECU reflash
« Reply #17 on: May 13, 2011, 11:31:34 AM »
I was hoping we will see some imperical data back on flies in / flies out / open flies earlier / reflash discussion....... It was an intersting discussion for me that based on the gracious position of "the customer is always right", we can get to the best overall solution without pulling flies.
Offline capt chaos
Re: ECU reflash
« Reply #18 on: May 21, 2011, 01:21:45 PM »
Hi, finally got my ECU out, unelected Brussels eureaucrats  >:(
It'll be on it's way to Texas (wherever that is...) Monday. Andy
2010 GTR1400 Magnesium
Offline kawasherpa
Re: ECU reflash
« Reply #19 on: May 21, 2011, 11:34:48 PM »
I have a ATRE, timing retard elimator.  It's about $150.  You have a choice of maps.  I run the top gear map so the flys open using the top gear map in all the gears.  You have choices of which gear map to use.  It also eliminates the top speed shut off.  You can feel the difference in the 60 to 85 MPR range.  More torque.  Fred's site shows how to install.  If you don't like it you can remove it in about 20 minutes.  Rick
