I plan to add a Muzzy full carbon/SS dual system soon.
Where in my area .... central Connecticut ... can I find a dyno? I don't want them to tune my bike, just give me baselines for each set up.
Thanx
Dr. Dyno is good, he lives in Conn., check his website. I had a bike done by him at Marcus Dairy and am very satisfied.
Dynojet's website has a full listing of their locations by state.
http://www.dynojet.com/dyno_centers/list_motorcycle.aspx
Did that search and was surprised to see that Dale Walker fled CA and relocated
Holeshot to BFG in Yerington, NV, which is just under an hour from where I live!
Now, if only he would come out with a full 4-1 system for the C14 instead of just a
slip on....
Yes, spoke with Dale about "making" me a 4-2-2 system. Said any thing can be done, but I figured it would be less of a problem to buy one already made. Plus, NV is not next door to CT.
Well, seeing how I live relatively close to him (I drove though Yerington last month on the way to Las Vegas), I should be the first to get a Holeshot 4-1 system.
I'm sure Dale can make you a header for the C14 ... but, I have a ZX14 header (new in the box) ... but, don't know how that would be different than just adding the mid pipe/Holeshot can??I don't want a 4-2, I want a 4-1 so that rules out the zx14 exhaust. Also, the reason I want a full exhaust instead of just the can is that collector tubes on the stock exhaust are tiny, aftermarket like Area P is bigger. Check them out, they are smaller than the collectors on my '91 Katana 1100, look similar in size to those on my old GS550.A motor this big shouldn't have such small pipes, it is a restriction that needs to be rectified.
Talk to Dale, as I may be missing something here.
Also, if Dale has a header for the ZX14, I'm sure he can make a mid pip and add a can to do what you want, m'friend.
I emailed Dale about plans for a future 4-1 for the C14 and he said there are none. He feels that the bike is not a zx 14, it is a sport tourer and thus doesn't need one. I think the c14 is a zx 14 that can tour, but I will not argue the point.
Oh, and by the way I have an appointment for this Saturday for a custom map on the dyno for my newly installed Muzzys dual system so I'll be posting the chart up, I pulled 133 hp on this same dyno with just a slip-on not long ago, we'll see soon enough...
ZG .... did you get the dyno reports from the dual system yet?
Also, was any 'retuning' required going from the slip on to the full system?
Yep, 13 hp gain over my prior base line run and 92 ft-lbs torque, I posted it on the dyno thread, she's smooth like silk now and pulls hard through the entire range!![]()
http://www.zggtr.org/index.php?topic=312.msg2543#msg2543
