Author Topic: Stebel HF80  (Read 3070 times)
Offline Tabarswaacky
Stebel HF80
« on: July 21, 2011, 03:22:10 PM »
Has anyone installed a set of Stebel HF80 horns on their C14 ?
In the instructions, you are directed  to connect two leads to the OEM wiring harness.
Anybody have an idea exactly where that is?
Do I have to take anything apart?
any help will be appreciated.  Thank You
Offline philipintexas
    • Phils Farkels
Re: Stebel HF80
« Reply #1 on: July 21, 2011, 04:00:42 PM »
Would that be the two leads at the stock horn?
Offline RBX QB
Re: Stebel HF80
« Reply #2 on: July 21, 2011, 04:08:02 PM »
"OEM Harness" would be the factory connections at the triple. While you don't HAVE to take things apart to make that connection, it sure makes things easier (unless you have tiny hands). The right upper fairing and trim panel will expose where the stock horn connects (and give you room to get your hands in there). It's just a couple spade-type electrical connectors, so pretty simple disconnect. You might even be able to do it from below by removing the small trim panel above the radiator, but still not a lot of maneuvering room from down there.
2011 Concours 14 ABS
Offline RedBombardier
Re: Stebel HF80
« Reply #3 on: July 22, 2011, 02:58:28 PM »
It is about as simple as it gets.  Laying on the floor look up the forks to where the horn is.  You can reach up and unplug the horn wires.  I have large hands and easily unplugged the wires.  One is the common and the other to fire the horn  If you are using a relay these wires are you want to use.  You will probably remove the OEM horn also.  One bolt I do believe... maybe two.  I use the Stebel air horn... you will love the improvement!
« Last Edit: July 22, 2011, 05:02:50 PM by RedBombardier »
Chris from the Big "D"
COG# 9361
AMA# 672853 Life
2009 Candy Diamond Red C14, Guhl. Delkevic
