Author Topic: Two Bothers Slip on on but loss all my low end torque :)  (Read 4771 times)
Offline wildnphx
« on: July 16, 2011, 07:54:55 PM »
So I put on a Two Brothers slip on with a new map in the power commander to match and I love the sound but the loss of low end torque is sad.  I wonder if I pony up for the full Area's P Exhaust if I will have the same problem?
Offline Conhardcore
  • 2011 Concours 14 Black
Re: Two Bothers Slip on on but loss all my low end torque :)
« Reply #1 on: July 16, 2011, 08:35:12 PM »
Maybe it's your MAP.  I just put on V&H CS1 on mine with no fuel adjustments and nothing close to loss of all low end torque.  I wouldn't think the Two Bro's would affect your bottom end that much.
« Reply #2 on: July 16, 2011, 08:39:20 PM »
'Two Bro's would affect your bottom end'.....hmmmm.....we'll have none of that on my watch, thank you very much!   :yikes:
Offline C1xRider
« Reply #3 on: July 16, 2011, 09:46:44 PM »
Wow, always going for the gutter  ;D
« Reply #4 on: July 16, 2011, 09:49:30 PM »
Ok, I must be slow tonight because I didn't get that at first, but now...  :yikes: :rotflmao:
Offline Conhardcore
« Reply #5 on: July 16, 2011, 09:59:40 PM »
had a feeling that one was gonna come back ;D
Offline Mighty
« Reply #6 on: July 17, 2011, 11:36:36 AM »
No issues with mine
No Flies, PC V, BMC Air Filter, Two Brothers Carbon Fiber, Deep Tint Windshield, Gen Mar risers
Honda TRX700XX
Yamaha Warrior 1000cc 4 stroke Sled
68 Rag top Vette
Offline Fearless
« Reply #7 on: July 21, 2011, 08:36:28 PM »
I had the same problem and it is a normal symptom but your mid-range and upper HP should increase. If you haven't pulled the flies yet, that will make a big difference in the low end torque.
If you're still  not happy, go with the Area-p full system. It rocks from the bottom up!
2008 C14 - Flies out, Area-P full system, PCV
Offline madcap
  • Only slightly nuts
« Reply #8 on: July 22, 2011, 07:49:44 AM »
I have the same setup - should be more power, not less - you have a setup problem. I'd suspect a map issue, and you may want to check the ground on that power commander - run a solid one straight to the battery if possible.
Anything you say, can and will be misquoted and used against you.
_________________________________________________
2009 CR14 - Red (ish)
« Reply #9 on: July 22, 2011, 08:16:45 AM »
^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^that
« Reply #10 on: July 22, 2011, 08:49:55 AM »
Thank goodness for Jim!   :thumbs:
