I just completed a valve adjustment. The cam sprockets and timing were lined up perfect. I seem to have everything reconnected. The fuel pump comes on, the dash looks normal, the starter spins the engine with gusto but it does not start, no sounds of combustion.
I initially forgot to ground the PCV. Fixed that but no change. Next I took the PCV out of the loop, still no change. Hopefully I am just missing something simple but what?
I performed the diagnostic at the dash - turned to on and pressed and held both buttons - nothing happens.
I have spark, at least at #1. Pulled the stickcoil, plugged in an old sparkplug and grounded to the engine case. Pressing the starter I see a spark..
Do FI engines get flooded?
