Author Topic: C-14 rotor diameter?  (Read 3196 times)
Offline myleslong
« on: July 13, 2011, 04:01:50 PM »
Who has measured the diameter of the rotors on the C-14?
I've heard that the rotors are common between the ZX-14 and the C-14.
If true, Brembo makes a full floating rotor for the ZX-14, but all of the Brembo vendors advertise two diameters for the ZX-14.
 320mm & 310mm.
I've used the full floating Brembos on my sport bikes and I've been very happy with them. I'm ready to do the same to the Connie but I want to make sure to order the right diameter.
Thanks in advance,
Myleslong
Offline 3redzxs
Re: C-14 rotor diameter?
« Reply #1 on: July 13, 2011, 04:15:53 PM »
I haven't measured but kaw specs say 310 mm.
« Reply #2 on: July 13, 2011, 04:23:30 PM »
According to Kawasaki they are 310 mm, as the other poster mentioned. They feel bigger after they warp though, a LOT bigger sometimes.  ;)
 320mm & 310mm.
Thanks in advance,
Myleslong
« Reply #3 on: July 13, 2011, 04:53:14 PM »
I would make sure that they are the same part number, otherwise you may be disappointed with the fitment.
Offline myleslong
« Reply #4 on: July 13, 2011, 05:16:11 PM »
Will confirm the same part number before ordering.
Thanks to all for the responses.
Myleslong
« Reply #5 on: July 13, 2011, 05:22:58 PM »
Another thing to consider...ABS or not?  10/11 bike vs 08/09?
« Reply #6 on: July 13, 2011, 07:29:14 PM »
I believe the rotors are the same diameters between all C-14's Jim. The rotor carrier is different on 2011's but the actual rotor itself appears to be identical to the earlier types. Of course the new rotor has a new part number because the rotor comes only with the carrier as an assembly.
« Reply #7 on: July 14, 2011, 04:08:01 AM »
Just sayin.....The Law of Unintended Consequences has a field day with this kind of thing.
