Author Topic: Battery For Rear TPS  (Read 3107 times)
Offline woodwickcandles
    • Woodwick Candles Canada
« on: July 13, 2011, 07:35:22 AM »
Warning message on front dash says battery sensor low for rear TPS.  I am about to change to Michelin Pilot Road 3 so this would be a great time to change battery.
Does anyone know if this is some type of "off the shelf" battery or something I need to order from dealer $$$...
John
John Lein
www.woodwickcandles.ca
Re: Battery For Rear TPS
« Reply #1 on: July 13, 2011, 07:48:25 AM »
Unless you are comfortable taking apart the TPS and soldering a new battery in then you might be better off if buying a new sensor.  There was a "how to" on the other forum and I can't find the thread that showed the process.  I think that Murph is also doing a TPS exchange where you send in your dead one and he sends you another back.  It might also be that he puts in a new battery and sends you your orignal one back.  Not sure, once again this was all on the old forum and I haven't had good luck searching through the pre-crash threads.
« Reply #2 on: July 13, 2011, 08:30:22 AM »
If the bike is still under warranty, you might see if the dealer will take care of the sensor replacement.
Offline C1xRider
« Reply #3 on: July 13, 2011, 01:42:23 PM »
And if they do, have them mount the new tire for free while they're at it.  You can offer to pay them to balance it as incentive.
Offline IRULE
  • How sweet it is...
« Reply #4 on: July 13, 2011, 11:08:15 PM »
Its definitely warranty item if you are still under warranty.  This is a great time for them to mount your new tire.  Make sure you ask nicely.
2009 Red Buell 1125CR
1978 Triumph Bonneville
