Author Topic: Clutch slipping at wide open throttle?  (Read 8890 times)
Offline Mister Tee
« on: July 11, 2011, 02:28:04 PM »
Okay this is the second time this has happened.  I launched hard on the straightaway, wide open throttle winding it up to near redline, shifted to third, locked up the clutch, and as the revs neared redline, there was some weirdness going on that felt like the clutch slipping, and I had to back off to lock it back up.  Anybody else have this happen?
Fried clutch?  I'm pretty easy on it and the bike has barely over 10K.
Re: Clutch slipping at wide open throttle?
« Reply #1 on: July 11, 2011, 02:42:55 PM »
It may be worn out in 10K miles, it all depends on how it was used. Some folks get more mileage out of wear items than others; 10K is a little short IMO but a clutch should not slip once fully engaged (released) under any circumstances. The other possibility is that there is something preventing the clutch itself from fully engaging; a sticking clutch slave cylinder or master cylinder, a clogged master cylinder reservoir port, etc. But again, the clutch should simply not slip at all once it is released.
« Reply #2 on: July 11, 2011, 02:58:19 PM »
rev limiter?????
Offline mcclaskeyj
  • Adventure...redefined
« Reply #3 on: July 11, 2011, 03:21:04 PM »
I just posted about the same issue last week sometime. I've got a Red '09 but mine did the same thing at about 5-6 1/2k RPMS. Kinda felt like either a loss of power at the wheel or like the tire was sliding but I'm almost positive it wasn't the latter. I've tried to get it to happen again but no luck yet. The engine continued to rev but just a loss of power at the wheel...strange indeed.  ???
'83 C70 Honda Passport   '06 Honda Rebel 250
'76 Kawasaki KZ400          '79 Suzuki GS1000L
'04 Kawasaki Ninja 250     '07 C14 ABS  '09 C14 Red                            '08 CRF230L
http://www.bikepics.com/members/mcclaskeyj/
Offline mcclaskeyj
« Reply #4 on: July 11, 2011, 03:23:58 PM »
I explained my issue in detail here: http://www.zggtr.org/index.php?topic=2160.0
Offline PH14
« Reply #5 on: July 11, 2011, 03:49:26 PM »
rev limiter?????
+1 That would be my guess as well.
Offline PH14
« Reply #6 on: July 11, 2011, 03:52:10 PM »
Did you even resolve your problem? The OP's issue seems different since it occurs near redline.
Offline IRULE
  • How sweet it is...
« Reply #7 on: July 11, 2011, 08:28:38 PM »
I launched hard on the straightaway, wide open throttle winding it up to near redline...I'm pretty easy on it and the bike has barely over 10K.
Really?
2009 Black Kawasaki Concours 14
2009 Red Buell 1125CR
1978 Triumph Bonneville
« Reply #8 on: July 11, 2011, 08:58:39 PM »
Really?
He was just clearing his C14's lungs.  I don't abuse my bike, but it will hit 10,000 rpm a couple times a week.
Offline IRULE
« Reply #9 on: July 11, 2011, 09:06:14 PM »
Is like saying you watch what you eat, but you eat Big Macs a few times a week...?
Is like saying you don't drink during the week, but man I get f#$ked up on the weekend!
« Reply #10 on: July 11, 2011, 09:16:35 PM »
Nope, its like saying that I use my bike like it was intended to be used.  Not abused.  I also don't baby it, because what fun would that be.
Are you the kind of guy that only runs your bike 4,000 rpm and holds up the Prius behind you.  ;D
Offline IRULE
« Reply #11 on: July 11, 2011, 09:26:26 PM »
Man, you got me.  ;D
Offline Jaxter
  • Blue might not be fastest, but it's my favorite
« Reply #12 on: July 11, 2011, 09:39:33 PM »
what could be more fun than holding up a prius speed freak
I've Never Had A Better Day
« Reply #14 on: July 12, 2011, 04:21:09 AM »
Sure p****s me off when a Super Sport Tourer is holding me up in the left lane....
« Reply #15 on: July 12, 2011, 04:58:46 AM »
Easy Jim, think about your mileage.
« Reply #16 on: July 12, 2011, 05:10:34 AM »
« Reply #17 on: July 12, 2011, 05:10:45 AM »
I think about it every day I keep passing those gas stations.....50+
« Reply #18 on: July 12, 2011, 05:11:13 AM »
You say this as if there's something wrong with it.    8)
Offline IRULE
« Reply #19 on: July 12, 2011, 09:18:34 AM »
Nothing wrong with it if you are doing it. Just don't tell us that you are easy on the bike when you are not. That's what Im saying.
