Author Topic: Recommendation for a cell phone holder  (Read 2867 times)
Offline RogerMurray
« on: August 20, 2022, 02:05:04 AM »
Spammer....  Signed up in March and was sleeping until now.  Banned..  I'm not removing the topic as it may be interesting to others.
« Last Edit: August 21, 2022, 05:09:20 AM by VirginiaJim »
Offline FTB530
Re: Recommendation for a cell phone holder
« Reply #1 on: August 20, 2022, 07:08:15 AM »
Quad lock
« Reply #2 on: August 20, 2022, 08:46:39 AM »
I have been extremely pleased with the RAM "X Grip".  It is far stronger than it looks.  Have a RAM ball on my handlebar risers and it places the phone right in the center.  Have been using it 7 years now, on every ride.  Note, there is a large and small version.  I am using the small, currently with a Samsung A52G5.
https://www.amazon.com/gp/product/B0055PH0XA
About the only negative is that I have to make sure the arm lands between my side volume control and power button.... otherwise it will press one of them :)
http://zggtr.org/index.php?topic=22890.msg284121#msg284121
http://zggtr.org/index.php?topic=18000.msg294219#msg294219
« Reply #3 on: August 20, 2022, 03:59:51 PM »
I also used the Ram x grip for several years. The only gripewas the tendency of the rubber or neoprene grippers to come off. Until recently. The x grip will let go of your phone. Mine came off when I turned into the wind atc120 mph. Ram now has a newer holder that i like and it looks like it is stronger and more wind resistant..it has a full back so the wind blast may pivot it back on the Ram ball but not nlow the phone out if the holder.
« Reply #4 on: August 21, 2022, 09:44:27 PM »
I also used the Ram x grip for several years. The only gripe was the tendency of the rubber or neoprene grippers to come off.
I have never had one let go.  But one was somewhat loose.  So I put some rubber cement on the inside and stuck it on and now it is very much on there :)
As for wind, that will likely depend on where it is mounted.  If it is low/center, I don't think it is ever a problem (I will only admit to having gone really fast, depending on ones' definition of "really fast").  Mine grips very strongly, and I can pull on the phone with force and it not come free.
For those very paranoid, RAM also has an option for a "tether", a rubber web that further secures the corners.  https://www.amazon.com/RAM-Mounts-X-Grip-Tether-RAM-TETHER1U/dp/B09M7S9YVL  I think they might include it with the RAM X Grip now (or so I have heard).  Wasn't with mine.  Wouldn't have used it, anyway.  But it is recommended for very high speed, non-fared, or off-road.
https://www.youtube.com/watch?v=NiYdGiSxFZs
The problem with most other mounts is that they require a specific case (that I don't want) or something stuck permanently to the back of the phone (which I also don't want) or require just too much difficulty putting the phone on or off.
Offline Big Red
« Reply #5 on: August 22, 2022, 08:41:03 AM »
I've used both the Quad Lock and X-grip. The X-grip I had just fell apart two weeks ago. The Quad Lock is still going strong.
Offline robertv
  • 2008 C14 Silver
« Reply #6 on: August 22, 2022, 02:30:22 PM »
What phone and case are you using? I would take a look at Peak Design's case and mount system which I use across my road bike, mountain bike and C14! It's an elegant and well thought out ecosystem and while it may seem pricey at first, reliability and ruggedness has been outstanding! And if you have the Ram ball already, all you would need is Peak Design's mount plus their case.
https://www.peakdesign.com/products/1in-ball-adapter
https://www.peakdesign.com/pages/mobile
Offline dbird29
« Reply #7 on: August 31, 2022, 08:31:12 AM »
I have a RAM X Grip that I use in the Jeep but am going to try the RAM Quick-grip for the bike. Easier in and out without adding anything to my case and Quad Lock doesnt have my phone model anyway.  https://www.ebay.com/itm/203534086263
2010 C14 Blue
2003 Buell XB9S
1982 GPz 750
