Author Topic: Hearted Grips, Bonehead move  (Read 3342 times)
Offline Coomers
« on: May 26, 2022, 06:31:04 PM »
Ok, I cant tell you how much of an Bonehead I am.
I had an 08 Conny with Murph's ProGrips and loved them. I now have an 18 Conny and find the grips very hard, I bet you know where I'm going with this.
So I ordered as set of Murph's ProGrips and then proceeded to cut the original grip off before realizing they are heated... Idiot! Idiot! Idiot!!!
Before I go to my Kawasaki Dealer with my tail between my legs has anyone come up with a good solution for a heated grip insert that will work well with Murph's Grips? I would really preferer the Murph's Grips but use the heated grips quite often.
Thank you for not laughing...
Offline dbird29
2010 C14 Blue
2003 Buell XB9S
1982 GPz 750
Re: Hearted Grips, Bonehead move
« Reply #2 on: May 26, 2022, 07:04:13 PM »
I had an 08 Conny with Murph's ProGrips and loved them. I now have an 18 Conny and find the grips very hard, I bet you know where I'm going with this.   So I ordered as set of Murph's ProGrips and then proceeded to cut the original grip off before realizing they are heated... Idiot! Idiot! Idiot!!![...]
More like horrified.
Yeah, just order some $15 (or something) grip puppies to slide over the stock grips once you repair them.  Done!
« Reply #3 on: May 27, 2022, 08:26:54 AM »
I wonder if you could use some snowmobile heaters?
https://www.denniskirk.com/sports-parts-inc/standard-length-high-power-grip-heater-sm-12474.p5903656.prd/5903656.sku
I have used items similar to those on several of my bikes, they worked fine except they did not have variable heat, just an on off switch.
Offline Coomers
« Reply #5 on: June 01, 2022, 11:52:04 AM »
Thanks Guys,
Not sure what I'm going to do yet but I do see a new Kawi Grip in my future.
Offline Big Red
« Reply #6 on: June 01, 2022, 12:00:54 PM »
I'd suggest tying into the factory wiring with an under-grip heater.
https://www.amazon.com/dp/B002OP5YDM/
