Author Topic: Dim Display Screen  (Read 8627 times)
Offline Wile
  • Kawasaki is Japanese for "Money Pit"
Dim Display Screen
« on: July 10, 2011, 11:49:21 PM »
My display screen went to about 1/2 brightness.  It's happened a couple of times once it went back during a ride and the other time it went back to normal after stoping for a rest.
Anyone else see this? Or is it like the flashing F1 curse? :P
2010 C14
Only a biker knows why a dog sticks its head out of a car window.
Past Bikes...  A bunch.  Current Bikes 1975 Z1 (the rat bike) and a 2010 C14
Re: Dim Display Screen
« Reply #1 on: July 11, 2011, 04:59:23 AM »
Was the sun shining on it at the time? Mine will turn dark at times when the sun is on it and heats it up.
« Reply #2 on: July 11, 2011, 05:41:40 AM »
Good point.  That is pretty typical for LCD.  LCD's are temperature sensitive.
« Reply #3 on: July 11, 2011, 05:56:46 AM »
If no sun, then take it into the dealer.  It's warranty.
« Reply #4 on: July 11, 2011, 10:15:35 AM »
Sitting in direct sunlight will do this, freaked me out first time too...  :o
Offline Shadowofshoe
  • Mastiff pup/human pup
« Reply #5 on: July 11, 2011, 02:11:36 PM »
    Yep sun..it did it on my Beemer...I also thought it broke.
            Mike
Sooooo....we are about to be a Nation that makes you prove you have insurance-but it's not necessary to prove that you are indeed a Citizen of that Nation?
Offline Wile
« Reply #6 on: July 11, 2011, 04:49:44 PM »
The sun is possible.  Didn't happen at night.  I'll just keep an eye on it for now and note the conditions if it happens again.
Thanks all.
Offline SimonSaysDie
« Reply #7 on: July 11, 2011, 08:17:06 PM »
Timing must be everything...this just happened to me today.  It's the first really hot day I've left it parked outside.  It was back to normal by the time I made the 25 mile ride home.  Kind of scared me at first though.
Offline IRULE
  • How sweet it is...
« Reply #8 on: July 11, 2011, 08:24:39 PM »
if you concern with the situation, take a picture or two, just in case you need to show the dealer for warranty.
2009 Red Buell 1125CR
1978 Triumph Bonneville
Offline Rawman
« Reply #9 on: July 12, 2011, 10:51:07 AM »
Yep, happened to me in Atlanta after leaving the bike outside at work all morning.  I went to go get lunch and had an all black LCD screen, scared the crap out of me too.  It did come back after a few miles.
2009 Non-ABS
« Reply #11 on: July 13, 2011, 03:49:18 PM »
« Reply #12 on: July 13, 2011, 03:55:16 PM »
All LCD displays will do that when they get overheated. They do not have to be in direct sunlight to fade, just get really warm.
It is not really a brightness thing, more of a contrast problem. The contrast will go back to normal after the display cools down.
2010 C14
Offline Wile
« Reply #13 on: July 13, 2011, 06:28:19 PM »
Is that supposed to be circular logic of some kind?
Ba ha ha ha :rotflmao:
Offline IRULE
« Reply #14 on: July 13, 2011, 11:06:16 PM »
circular logic = B.S.!
« Reply #15 on: July 14, 2011, 05:00:04 AM »
It's an endless loop! What have I done?  :o
Offline firetruck41
  • No pictures means No Posting
« Reply #16 on: July 14, 2011, 06:58:28 AM »
my LED is more visible during the day, than at night. at night it has a 80% clarity look.
2011 connie. silver
corbin seat on order
motorcycle larry lowers.murphys risers
Givi E55 mono-key. passenger peg lowers
« Reply #17 on: July 14, 2011, 09:27:42 PM »
Unless the circle at hand consists of the "golden rule" =)
Offline Wile
« Reply #18 on: July 17, 2011, 04:05:29 PM »
UPDATE
It was a heat issue.  Smoking hot day this past Saturday.  Left the bike in the sun for a few hours and when I took off it was dim again.  Came back once it cooled off. Still the trip to Sturgis last year wasn't a trip to the Tundra.  It was very hot and it didn't go dim out there. Hmmm
Offline jonathan
« Reply #19 on: July 18, 2011, 09:03:38 AM »
I've found that it's not so much heat related as sun related. If the cluster is in direct sunlight this can happen but if the bike is parked facing into the sun so that the cluster is shaded then there is no problem.
