« Reply #6 on: August 29, 2021, 06:31:39 PM »
If you're not in the engines powerband you're not ready for an emergency. ymmv
Well, one is not ideally ready for an emergency that requires power when cruising in low RPM, that is true. But it doesn't affect braking/slowing down. And from my experience, about 90% of emergency situations, I need to slow (as opposed to accelerate).
What one defines as a power band will vary quite a bit. I would not want to accelerate hard on the C14 below 4-5K. But cruising at such an RPM isn't comfortable (noise, vibration), and also less fuel efficient. So there is a balance. Two rules that are good- if you think you might need power, downshift immediately. And if you don't, still be ready to downshift.
« Last Edit: August 30, 2021, 05:48:20 AM by maxtog »
Logged
